is there option like this in prog ? from it see the active filters and change fiter options from them ?
then i open pdvd11 and from it i can change miscallaneous to dxva
this is the only way i can change the filter option
so how can i check the filter and thier options ?
thx
Re: how can check active filters at prog
#2Try File menu > Properties option > Video decoder
| Prog demux |
| Prog demux |
