New version in pre-release page.
Improve of multi-channel playback. Dual Tuner support + possibility not to close the device and timeshift during switching on the channel from other device or iptv. You can back to old channel without lost of timeshift.
Support of Multi-stream transponders and hardware blindscanner. In this version only over CrazyCat modules (At this moment for Prof 7500 and Omicom).
Remake Scan Transponder dialog + some improves of scanner.
New settings and current fixes.
New Splash window.
Re: ProgDVB 6.7x / Engine 5.1 testing
#2When you provide support for TBS6925 card, the same module from CrazyCat?Hopefully soon!ThanksProg wrote:Support of Multi-stream transponders and hardware blindscanner. In this version only over CrazyCat modules (At this moment for Prof 7500 and Omicom).
#4very very very bad with diseqc 4 port
the 6.65 is the best !
#5Is it working in current version?satesco wrote: When you provide support for TBS6925 card, the same module from CrazyCat?Hopefully soon!Thanks
#6new version ProgDVB6.72Pro
bad with diseqc 4*1
tevii dvbs-2 s464 final driver from tevii.com
win7 x64
bad with diseqc 4*1
win7 x64
#9Sorry for the late response,but ProgDVB with CrazyCat's module works great.Thanks.Prog wrote:Is it working in current version?
#11when astra 19 E in port 1
the diseqc not work good
when any other sat in port 1 work good
and
this version is very best
ProgDVB6.65Pro with all and with astra 19e in port 1
and
#12Hello, go to viewtopic.php?f=4&t=7038
I would appreciate it implemented in the new Engine 5.1. thanks
#15hi
i have downloaded and installed the latest version of progdvb 6.72.8 x64 on my win 7.as i want to use my card it shows a message "[{bda} tbs qbox dvb-s2 tuner] device not started"
my card is tbs qbox dvb-s2 usb;
please help me
please help me
