Hello!
I find very often that after starting the program the broadcast won´t boot, it just stay black so I have to restart it. Can you help me how to solve it? I have the latest version. Thanks!
Re: after starting the program the broadcast won´t boot
#3What dvb device? Do you start other software before that? Do you have diseq? ...
#4I have Windows 7x64, ProgDVB v6.70.3.x32 Professional, Skystar HD2 and diseq for two satellites. I am watching the broadcast only through yours software.Prog wrote:What dvb device? Do you start other software before that? Do you have diseq? ...
#5Forget about the expression "broadcast", as people would normally think about a special network streaming mode then.
If I understand you well, you are complaining about not getting sound and vision from any station, on the computer, that contains your tuner.
If so, do you get any good Level / Quality readings?
If not, perhaps you may have to do some device settings, to allow ProgDVB to control your tuner.
If yes, you may have to install some x64 compatible codecs.
Did you try with the original software (or any other), with what results?
BTW, this may bring codecs required, possibly also available system wide then.
AFAIK, thew original software should also be available for 64 bit systems.
