I have transferred the channels to my netbook pc.
All working ok , even the positioner is ok.
The problem is ,
when i scan for new channels ,
it creates a new eg. 0.8W channelist.
Now i have 2 0.8W channelists
How to tell it to use my old channelist to add channels?
Re: Transferring channels to 2nd PC and new scanning
#2It is not good idea copy channels from one PC to other. Because different DVB devices give different channels ID.
#3You can copy the transponders list (all.list) and the diseqc.tree, then do a rescan of all sats.
#4as the author said it aint good to transfer them as it can cause problems.
however here are teh files you will be looking for
in the root of progdvb look for .dat files that contains most of the settings as well as .ini files
the folder that should probally also be copied are teh channels, transponders adn plugins
i think the channels folder shoudl sovle yoru problem as it has the scans already
