Hi,
i have just installed the latest 6.80.1 but i noticed that the display has become choppy. Its like it drops frames or running slowly.
CPU usage and RAM are all fine.
I have reverted back to 6.73.4 and its all fine.
Re: Progdvb 6.80.1 display problem
#3Please compare demux and audio renderer in old and new versions. New version use Prog Demux in default settings.
#4previous and latest version use prog demux and progar for audio.
#5Please send me files from logs directory of last version (You can install to other directory without uninstall old one).
#6For me audio or video seems ok with version 6.80.1 (or 6.80.01)
Even the jurassic DPI font size problem is fixed now
I see theres a confusion about versions numbering, I think there was a pre-release with that number already.
I would suggest pre-release versions use letters, for exemple 6.80.a , 6.80.b....
Using win7 32bits, prog demux, prog audio render, primary audio device.
Last week i instaled VC++ 2008 SP1 redistributable, believe i got a stabitily improovement in audio and video since then.
#8I found a channel with this problem, it happens with this: HD + 4.2.2 + fddshow codec.
The same channel with elecard codec runs smooth.
Couldnt open it with any other codec (no video).
