Pinnacle PCTV Sat - Remote control issue
Hello,
I am using Progdvb with an old Pinnacle PCTV Sat.
As I could remember, before i was able to use the remote with no problem.
Then I didnt use Progdvb for a long time and when i decided to reinstall it, now i can't use the remote at all.
I confirm that it is well set, the remote with its driver working (I can test it perfectly with the tester provided by Pinnacle).
But once i am on Progdvb, nothing.
I tried to select in Option --> control --> tried all of choice. Nothing.
I've downloaded the plugins "Pinnacle remote control 3" on Progdvb website. There is a file, i tried to put it in some directories (Plugins / remotes...). But still none.
Anyway... I spent more than 2 hours trying to fix this issue.
Can someone help me please ?
Thank you very much in advance.
Re: Pinnacle PCTV Sat - Remote control issue
Hello,
thx for your answer.
Actually, im having this issue on the latest version of ProgDvB.
I also tried to install some older version, but same cases.
In the plugins section, there is a file to download about this RC. But I dont know why, doesnt work.
As i said, i was using it before. Well i never configured it properly, so that time i just use up and down keys, volume...
Anyway, it was interacting with ProgDvb at least.
