Re: SAT>IP Protocol support
#303
Hi Prog (after much time)!
I'm doing some testing with TVHeadEnd as a SAT>IP server.
Now I found a big problem with ProgDVB as a SAT>IP client:
- Using version ProgDVB 7.12.07
- SAT>IP device configured only for SAT.
- When doing a Manual Scanning:
* Select a valid transponder.
* Pick "Scan"
- No channels detected.
In the logs of the server I see this:
1) ProgDVB send a SETUP command with pids=
2) After 5 seconds ProgDVB sends a TEARDOWN command.
From my experience with the SAT>IP protocol, the regular procedure is:
1) Send SETUP command (without pids=, but is valid to do it)
2) Send PLAY command (tipically with pids=, but not mandatory)
3) Get the stream over RTP.
4) Send TEARDOWN.
My question is: Why you are not sending the PLAY command?
I hope you can improve the SAT>IP client implementation. At time you can use several "software" servers.
Regards! ;)
#305
Hi Prog,
With last version (7.13.00 x64)) the same behaviour: no signal/lock in all transponders!
Yes, ProgDVB works with ALi SAT>IP server, but not with other SAT>IP servers.
Please, try to install some software SAT>IP server, like TVHeadend or Minisatip (Linux, free) or DVBViewer Recording Service (Windows, pay), and check compatibility. Or if you like, I can check in my environment (I have all of them for testing).
I hope you can improve SAT>IP support! :)
Best!
#307
Prog wrote:Can you check my logs?
Yes,
[ProgDVBEngine.log]
09:16:07.691 - FilterManager::OnSetTransponder CScannerManager::CreateEnvironment
09:16:07.691 -
09:16:07.691 - DevicesManager::SetTransponder 11856000
09:16:07.691 -
09:16:07.691 - TransponderManager::SetTransponder (TR) satip://192.168.1.60/?src=1&fe=1&freq=11856.0&sr=27500&pol=v&msys=dvbs&fec=34&pids=0,1,16,17,18
09:16:07.691 - --SwitchEngineTransport TS
09:16:07.691 - --SwitchEngineTransport end
09:16:07.691 - Api2Device::SetTransponder satip://192.168.1.60/?src=1&fe=1&freq=11856.0&sr=27500&pol=v&msys=dvbs&fec=34&pids=0,1,16,17,18
09:16:07.691 - Api2Device::SetTransponder result OK delay 0 ms
09:16:07.691 - TsInputTrafficProcessor::OpenTransponder 0
09:16:07.691 - FilterManager::OnSetTransponder SetTransponder
09:16:07.691 - ModuleList::ChangeChannel 0
09:16:07.691 - FilterManager::OnSetTransponder ScanTrasponderParseTS - satip://192.168.1.60/?src=1&fe=1&freq=11856.0&sr=27500&pol=v&msys=dvbs&fec=34&pids=0,1,16,17,18
09:16:10.895 - FilterManager::OnSetTransponder ScanTrasponderParseTS - satip://192.168.1.60/?src=1&fe=1&freq=11856.0&sr=27500&pol=v&msys=dvbs&fec=34&pids=0,1,16,17,18
09:16:12.880 - * s:0 q:0 tr=0 (0) NotSupported
09:16:13.662 - * s:0 q:0 tr=0 (0) NotSupported
09:16:14.162 - * s:0 q:0 tr=0 (0) NotSupported
09:16:14.662 - * s:0 q:0 tr=0 (0) NotSupported
09:16:15.162 - * s:0 q:0 tr=0 (0) NotSupported
09:16:15.662 - * s:0 q:0 tr=0 (0) NotSupported
09:16:16.162 - * s:0 q:0 tr=0 (0) NotSupported
09:16:16.663 - * s:0 q:0 tr=0 (0) NotSupported
09:16:17.163 - * s:0 q:0 tr=0 (0) NotSupported
09:16:17.663 - * s:0 q:0 tr=0 (0) NotSupported
09:16:18.163 - * s:0 q:0 tr=0 (0) NotSupported
09:16:18.663 - * s:0 q:0 tr=0 (0) NotSupported
09:16:19.163 - * s:0 q:0 tr=0 (0) NotSupported
09:16:19.663 - * s:0 q:0 tr=0 (0) NotSupported
09:16:20.163 - * s:0 q:0 tr=0 (0) NotSupported
09:16:20.664 - * s:0 q:0 tr=0 (0) NotSupported
09:16:21.164 - * s:0 q:0 tr=0 (0) NotSupported
09:16:21.664 - * s:0 q:0 tr=0 (0) NotSupported
09:16:22.164 - * s:0 q:0 tr=0 (0) NotSupported
09:16:22.664 - * s:0 q:0 tr=0 (0) NotSupported
09:16:23.165 - * s:0 q:0 tr=0 (0) NotSupported
09:16:23.665 - * s:0 q:0 tr=0 (0) NotSupported
09:16:24.164 - * s:0 q:0 tr=0 (0) NotSupported
09:16:24.665 - * s:0 q:0 tr=0 (0) NotSupported
09:16:25.165 - * s:0 q:0 tr=0 (0) NotSupported
09:16:25.665 - * s:0 q:0 tr=0 (0) NotSupported
09:16:26.165 - * s:0 q:0 tr=0 (0) NotSupported
09:16:26.666 - * s:0 q:0 tr=0 (0) NotSupported
09:16:27.166 - * s:0 q:0 tr=0 (0) NotSupported
09:16:27.666 - * s:0 q:0 tr=0 (0) NotSupported
09:16:28.166 - * s:0 q:0 tr=0 (0) NotSupported
09:16:28.667 - * s:0 q:0 tr=0 (0) NotSupported
09:16:29.167 - * s:0 q:0 tr=0 (0) NotSupported
09:16:29.667 - * s:0 q:0 tr=0 (0) NotSupported
09:16:30.167 - * s:0 q:0 tr=0 (0) NotSupported
09:16:30.652 - * s:0 q:0 tr=0 (0) NotSupported
09:16:31.152 - * s:0 q:0 tr=0 (0) NotSupported
09:16:31.652 - * s:0 q:0 tr=0 (0) NotSupported
09:16:32.152 - * s:0 q:0 tr=0 (0) NotSupported
09:16:32.652 - * s:0 q:0 tr=0 (0) NotSupported
09:16:33.152 - * s:0 q:0 tr=0 (0) NotSupported
09:16:33.653 - * s:0 q:0 tr=0 (0) NotSupported
09:16:34.153 - * s:0 q:0 tr=0 (0) NotSupported
09:16:34.653 - * s:0 q:0 tr=0 (0) NotSupported
09:16:35.153 - * s:0 q:0 tr=0 (0) NotSupported
09:16:35.653 - * s:0 q:0 tr=0 (0) NotSupported
09:16:36.153 - * s:0 q:0 tr=0 (0) NotSupported
09:16:36.653 - * s:0 q:0 tr=0 (0) NotSupported
09:16:37.153 - * s:0 q:0 tr=0 (0) NotSupported
09:16:37.654 - * s:0 q:0 tr=0 (0) NotSupported
09:16:38.154 - * s:0 q:0 tr=0 (0) NotSupported
09:16:38.654 - * s:0 q:0 tr=0 (0) NotSupported
09:16:39.154 - * s:0 q:0 tr=0 (0) NotSupported
09:16:39.654 - * s:0 q:0 tr=0 (0) NotSupported
09:16:40.154 - * s:0 q:0 tr=0 (0) NotSupported
09:16:40.654 - * s:0 q:0 tr=0 (0) NotSupported
09:16:41.154 - * s:0 q:0 tr=0 (0) NotSupported
09:16:41.655 - * s:0 q:0 tr=0 (0) NotSupported
09:16:42.155 - * s:0 q:0 tr=0 (0) NotSupported
09:16:42.655 - * s:0 q:0 tr=0 (0) NotSupported
09:16:43.155 - * s:0 q:0 tr=0 (0) NotSupported
09:16:43.656 - * s:0 q:0 tr=0 (0) NotSupported
09:16:44.171 - * s:0 q:0 tr=0 (0) NotSupported
09:16:45.156 - * s:0 q:0 tr=0 (0) NotSupported
09:16:45.422 -
09:16:45.422 - Stop engine
09:16:45.422 - DevicesManager::Stop
09:16:45.422 - DevicesManager::Free devices
09:16:45.437 - TransponderManager::~TransponderManager
09:16:45.437 - ModuleList::Free
09:16:45.437 - DevicesManager::Free RC
09:16:45.437 - Engine stopped
09:16:45.703 - HugeMemoryBlocksManager::FreeAll
[rtsp.log]
09:16:05.300 - ====================
09:16:07.660 - ----- too long wait of TEARDOWN answer
09:16:07.691 - ------ rtsp://192.168.1.60/?src=1&fe=1&freq=11856.0&sr=27500&pol=v&msys=dvbs&fec=34&pids=0,1,16,17,18
09:16:07.691 - delayed add pid17
09:16:07.691 - delayed add pid16
09:16:07.707 - delayed add pid0
09:16:07.722 - >> OPTIONS rtsp://192.168.1.60/?src=1&fe=1&freq=11856.0&sr=27500&pol=v&msys=dvbs&fec=34&pids=0,1,16,17,18 RTSP/1.0
CSeq: 15724
User-Agent: Wget/1.9.1
09:16:07.769 - ==================== 78
09:16:07.769 - RTSP/1.0 200 OK
CSeq: 15724
Public: OPTIONS,DESCRIBE,SETUP,PLAY,TEARDOWN
09:16:07.769 - -- TS RTP Client
09:16:07.769 - >> SETUP rtsp://192.168.1.60/?src=1&fe=1&freq=11856.0&sr=27500&pol=v&msys=dvbs&fec=34&pids=0,1,16,17,18 RTSP/1.0
CSeq: 15725
Transport: RTP/AVP;unicast;client_port=57456-57457
09:16:07.800 - ==================== 136
09:16:07.800 - RTSP/1.0 200 OK
CSeq: 15725
Session: BF185908;timeout=30
com.ses.streamID: 10
09:16:10.895 - delayed del pid0
09:16:10.895 - delayed del pid1
09:16:10.895 - delayed del pid17
09:16:10.895 - delayed del pid16
09:16:12.817 - >> TEARDOWN rtsp://192.168.1.60/?src=1&fe=1&freq=11856.0&sr=27500&pol=v&msys=dvbs&fec=34&pids=0,1,16,17,18 RTSP/1.0
CSeq: 15726
Session: BF185908
09:16:12.848 - << RTSP/1.0 404 Not Found
CSeq: 15726
Session: BF185908
[NetClient.log]
09:16:05.128 - Starting new channel:
09:16:05.128 - SubID 0 index=0
09:16:05.128 - closesocket 2540 0x23038790
09:16:05.128 - closesocket 2584 0x2308AFD0
09:16:05.128 - opensocket TCP 1300 0x23066680 net 0.0.0.0 554
09:16:05.159 - connected 1300
09:16:05.206 - UDP & Bind 57454
09:16:05.300 - RTSP: Error! not server port and dest.
09:16:07.660 - Async close 1300
09:16:07.660 - SubID 0 on founded.
09:16:07.660 - DoNextSubChannel - no next url!
09:16:07.691 - Starting new channel:
09:16:07.691 - SubID 0 index=0
09:16:07.691 - opensocket TCP 2540 0x23000DB0 net 0.0.0.0 554
09:16:07.722 - connected 2540
09:16:07.769 - UDP & Bind 57456
09:16:07.800 - RTSP: Error! not server port and dest.
09:16:07.816 - exit thread 0x23066680 st=4
09:16:10.301 - Skip error 10060
09:16:12.817 - Skip error 10060
09:16:12.848 - exit thread 0x23000DB0 st=4
09:16:12.880 - Async close 2540
09:16:12.880 - SubID 0 on founded.
09:16:12.880 - DoNextSubChannel - no next url!
09:16:45.422 - closesocket 1304 0x23038790
09:16:45.422 - closesocket 1300 0x23066680
09:16:45.437 - closesocket 2616 0x2308AFD0
09:16:45.437 - closesocket 2540 0x23000DB0
In my opinion is relevant:
1) The message "RTSP: Error! not server port and dest." in NetClient.log
2) After the SETUP message ProgDVB doesn't sends the PLAY command. Remember that the protocol steps are: OPTIONS, SETUP (mandatory), DESCRIBE (optinal), PLAY (mandatory), TEARDOWN. So, after the SETUP if you like to test the tuner status, then you need to use the DESCRIBE command. So, if you wait for packets without sending the PLAY command, you will never received them!
I hope you can improve the SAT>IP support!
#308
try setup SAT>IP again.
On my PC logs like
OPTIONS rtsp://192.168.88.24/?src=1&fe=1&freq=11053.0&sr=2894&pol=v&msys=dvbs&fec=34&pids=0,1,16,17,18
SETUP rtsp://192.168.88.24/?src=1&fe=1&freq=11053.0&sr=2894&pol=v&msys=dvbs&fec=34&pids=0,1,16,17,18
PLAY rtsp://192.168.88.24:554/stream=3?src=1&fe=1&freq=11053.0&sr=2894&pol=v&msys=dvbs&fec=34&pids=0,1,16,17,18
PLAY rtsp://192.168.88.24/?addpids=17,1,16,0
#309
Prog wrote:try setup SAT>IP again.
:?: :?: :?: My test is after changing the SAT>IP DVB-S2 server IP in the options window.
I the logs I see that ProgDVB doesn't sends the PLAY command (yes with ALi server).
And, why the error "RTSP: Error! not server port and dest." ?
I feel the problem can be: ProgDVB doesn't parse some RTSP response right... and consequently discards the response, and then it don't continue.
This can be real?
#314
Hi,
Triax TSS 400 does not work for me. What am I doing wrong?
I have configured ProgDVB with Sat>IP source, pointed it to the Triax, scanning found a huge bunch of channels, but playback shows just "Error!" in the status line.
Con you please help me? Thanks in advance!
