Diefenthal wrote:not all Sat>Ip Server Support pids=all Parameter
the Triax tss 400 is one of that
Yes, I know. Moreover, some of them understand the parameter but don't really send the full TS, as they don't have sufficient power (the result is a stream with several discontinuities). For example, for transponders with 30 or more megabits some of them lacks the needed power.
But, this isn't relevant for the software. If the server understand the request, then you receive the stream. My suggestion is very simple: When some plugin (the TS Recorder or som eother) request for the full transport stream (using fake pid 8192), then send a command to the SAT>IP for set pids to all (with addpids or with setpids, as not all servers support addpids).
This is required, because at time the TS Recorder is saving the full transport stream, but the ProgDVB isn't receiving the full transport stream. The reason is logic: at time the program don't request the change of the pid filtering in the server prior to enable the full TS; as a consequence it don't reveice the full transport stream.
I hope Prog can implement this change.
