I've the latest version of progdvb standard edition and I can't see any channel in frequency 11258.50 (Astra 19.2).
I've tried with other software, and all works fine.
It is a possible bug?
Re: specific frequency does not working
#3Hi,
I tried manual and auto scan, and I have the channels in my channel list with the correct parameters (PIDs). The problem is that seems that progdvb can't receive data from this frequency.
I tried also different video (and audio) codecs and renders and the problem persists.
The rest of frequencies that I'm using work fine. when I open a chanel, I see this infromation in the OSD: and immediately after I can see the channel,
But when I open a channel in this frequency, the bitrate information never appears: and I can't see anything.
Thanks
Thanks
#4Do you have signal/quality level in manual scanner on this transponder?
#5Yes, similar to the other frequencies.
I've tried also older Progdvb versions, and the problem persists.
I don't know where is the problem, the weirdest thing of all is that just fails this frequency.
With other DVB Software I can see it, so I think is not problem of the LNB or the PC card.
#6I opend this thread 1 years ago and I still have the same problem.
I tried lots of diferent Video, audio and Demultiplexor configurations and the problem presists.
Seems like for some channels, the checkbox "open channel without playback" of the "Settings-->Otions-->Main" is activated.
Is there a way to activate the logs of ProgDVB to see what happens when I open the channel?
thanks
thanks
#7I activated the logs in the options and now I can see that for 1 channel I can´t see, i get all the time this message:
20:45:04.051 - * s:89 q:100 tr=10684416 (0)
20:45:05.356 - MediaTypeDetection buffer reset!!
20:45:06.057 - * s:89 q:100 tr=10660352 (0)
20:45:07.577 - MediaTypeDetection buffer reset!!
20:45:08.049 - * s:89 q:100 tr=10612224 (0)
20:45:09.378 - MediaTypeDetection buffer reset!!
20:45:10.048 - * s:89 q:100 tr=10636288 (0)
20:45:10.922 - MediaTypeDetection buffer reset!!
20:45:12.046 - * s:89 q:100 tr=10636288 (0)
20:45:12.702 - MediaTypeDetection buffer reset!!
20:45:14.041 - * s:89 q:100 tr=10612224 (0)
20:45:14.470 - MediaTypeDetection buffer reset!!
20:45:15.782 - MediaTypeDetection buffer reset!!
20:45:16.049 - * s:89 q:100 tr=10708480 (0)
20:45:17.609 - MediaTypeDetection buffer reset!!
20:45:18.064 - * s:89 q:100 tr=10708480 (0)
20:45:19.006 - c:key 1
20:45:19.085 - * s:89 q:100 tr=5438464 (0)
20:45:19.108 - MediaTypeDetection buffer reset!!
20:45:20.703 - * s:89 q:100 tr=8614912 (0)
20:45:21.109 - MediaTypeDetection buffer reset!!
20:45:22.047 - * s:89 q:100 tr=7147008 (0)
20:45:23.171 - MediaTypeDetection buffer reset!!
20:45:24.048 - * s:89 q:100 tr=10660352 (0)
20:45:24.605 - MediaTypeDetection buffer reset!!
20:45:25.978 - MediaTypeDetection buffer reset!!
20:45:26.050 - * s:89 q:100 tr=10660352 (0)
#10Looking at the logs, I detected that for the channels whcih don't work, I never see the log line:
########################### Mark of finish channel changing. (4.328ms) #############
instead, the channels that are working I can see the previous log line
#11More precisely,
Working channels marks:
########################### Mark of start channel changing.###########################
#################### Start stream. (1.906ms) #######################
#################### First traffic. (2.265ms) #######################
########################### Mark of finish channel changing. (4.187ms) #############
########################### First video frame. (5.203ms) #############
The channel starts to work --> I can see video and listen audio
No working channels marks:
The channel doesn't work --> no video and no audio
#131. Is it free channels?
Please record me this transponder. Service->TS recorder->All TS. Need 4-5 minues and file must be large.
#15May be your CI (or plugin) not good for channel? Try record and playback file in other software
