Hello
I use this setting fir time shift :
All channels from transponder store in buffer.
but when I change channel (same frequency), it will be going to the first of time shift in new channel.
look to this picture(this picture show the new channel that i go to it) :
I want that when I change channel , in new channel time shift go to the end . Like red arrow on the picture .
my progdvb professional version is 7.16.03
in 7.11 version I didn't have this problem
what should i do ?
thanks alot
Re: Problem in Time Shift !
#3HelloProg wrote:btw, it is depended from channel? From demux? (Main page of options)
I did not understand what you mean.
I use time shift for all channels which are in same frequency.
when I change channel (same frequency) , time shift navbar go to the first of channel time shift . like that picture .
I want when I change channel (same frequency) , time shift navbar go to the end !
#5Time Shift is For All channels !Prog wrote:Same problem if timeshift only for one channel?
in ProgDVB 7.11.01 I chaeck and every thing was OK .
again I say My Problem with 2 picture :
1- Current channel that I watch :
2- Whan I change Channel :
when I change channel , navbar arrow go to the first of time shift !
how should I fix this problem ?
#9Thank youProg wrote:Sorry. I am very busy not and still not test this problem
if you have time, please check it
thanks
#10Still not. It is not easy problem. Because in this mode you have many channels and not all channels start in same time. Some space on right of timeshift is normal. But I am not have idea why in old version not same.
#11yesProg wrote:Still not. It is not easy problem. Because in this mode you have many channels and not all channels start in same time. Some space on right of timeshift is normal. But I am not have idea why in old version not same.
but in older version work very well
when you change channel (same frequency and time shift for all channel) it migrate to the first of time shift
and now i should use older version
