Progdvb Hd Homerun
sorry for my bad english
i try to configure HdHome Run Extend HDTC-2US to get ATSC North America channels but when try to activate BDA device get error message this message persist in both device , any help will be great
Re: Progdvb Hd Homerun
I too would like to try progdvb with its claimed ATSC support but no joy.
The OP's logs seem to imply progdvb thinks the HDHR is a DVB-S device so seems lika a programming bug.
It is too bad progdvb doesn't support the most popular ATSC tuner.
Hopefully it gets fixed.
21:03:06.969 - Start logging...
21:03:06.969 - GetBdaTunerList
21:03:06.970 - tuner Silicondust HDHomeRun Tuner 105287AD-0 -  -
21:03:07.228 -   Silicondust HDHomeRun Tuner 105287AD-0 ex:56781 type:DVB-C
21:03:07.229 - tuner Silicondust HDHomeRun Tuner 105287AD-1 -  -
21:03:07.487 -   Silicondust HDHomeRun Tuner 105287AD-1 ex:56782 type:DVB-C
21:03:07.488 - GetInfo 2
21:03:07.488 - CreateExtApi default
21:03:07.489 - MIS/PLP NOT supported
21:03:07.490 - GetModuleInfo {BDA} Silicondust HDHomeRun Tuner 105287AD-0 56781
21:03:07.490 - exIndex 0
21:03:07.490 - maxfilters 128
21:03:07.490 - caps 200304
21:03:07.490 - PossibleStart 1
21:03:07.490 - CreateExtApi default
21:03:07.491 - MIS/PLP NOT supported
21:03:07.492 - GetModuleInfo {BDA} Silicondust HDHomeRun Tuner 105287AD-1 56782
21:03:07.492 - exIndex 1
21:03:07.492 - maxfilters 128
21:03:07.492 - caps 200304
21:03:07.492 - PossibleStart 1
21:03:17.613 - GetInfo 2
21:03:17.614 - CreateExtApi default
21:03:17.615 - MIS/PLP NOT supported
21:03:17.615 - GetModuleInfo {BDA} Silicondust HDHomeRun Tuner 105287AD-0 56781
21:03:17.615 - exIndex 0
21:03:17.616 - maxfilters 128
21:03:17.616 - caps 200304
21:03:17.616 - PossibleStart 1
21:03:17.616 - CreateModule 56781
21:03:17.616 - CBDAManager
21:03:17.616 - BDAManager::Start 56781
21:03:17.616 - index 0
21:03:17.616 - CreateExtApi default
21:03:17.618 - BuildGraph
21:03:17.621 - LoadNetworkProvider DVB-C
21:03:17.622 - System NetworkProvider!
21:03:17.626 - GetTunerSpace DVB-C
21:03:17.626 - CTuneRequestSwitchManager::SetDefaultTunerRequst apply err Error in put tuner request
21:03:17.626 - Error in default request!
21:03:17.626 - Connecting NetworkProvider -> Silicondust HDHomeRun Tuner 105287AD-0 ... ERROR!!!
21:03:17.626 - !!!BuildGraph error Cannot connect network provider
21:03:17.627 - TearDownGraph OK
21:03:17.872 - ~CBDAManager
21:03:17.872 - PowerOff
21:03:17.872 - Stop
21:03:17.873 - GetInfo 2
21:03:17.873 - CreateExtApi default
21:03:17.874 - MIS/PLP NOT supported
21:03:17.875 - GetModuleInfo {BDA} Silicondust HDHomeRun Tuner 105287AD-1 56782
21:03:17.875 - exIndex 1
21:03:17.875 - maxfilters 128
21:03:17.875 - caps 200304
21:03:17.875 - PossibleStart 1
21:03:17.875 - CreateModule 56782
21:03:17.875 - CBDAManager
21:03:17.876 - BDAManager::Start 56782
21:03:17.876 - index 1
21:03:17.876 - CreateExtApi default
21:03:17.877 - BuildGraph
21:03:17.881 - LoadNetworkProvider DVB-C
21:03:17.881 - System NetworkProvider!
21:03:17.885 - GetTunerSpace DVB-C
21:03:17.885 - CTuneRequestSwitchManager::SetDefaultTunerRequst apply err Error in put tuner request
21:03:17.885 - Error in default request!
21:03:17.885 - Connecting NetworkProvider -> Silicondust HDHomeRun Tuner 105287AD-1 ... ERROR!!!
21:03:17.886 - !!!BuildGraph error Cannot connect network provider
21:03:17.886 - TearDownGraph OK
21:03:18.131 - ~CBDAManager
21:03:18.131 - PowerOff
21:03:18.131 - Stop
21:03:19.938 - GetInfo 2
21:03:19.938 - CreateExtApi default
21:03:19.939 - MIS/PLP NOT supported
21:03:19.939 - GetModuleInfo {BDA} Silicondust HDHomeRun Tuner 105287AD-0 56781
21:03:19.940 - exIndex 0
21:03:19.940 - maxfilters 128
21:03:19.940 - caps 200304
21:03:19.940 - PossibleStart 1
21:03:19.940 - CreateExtApi default
21:03:19.941 - MIS/PLP NOT supported
21:03:19.942 - GetModuleInfo {BDA} Silicondust HDHomeRun Tuner 105287AD-1 56782
21:03:19.942 - exIndex 1
21:03:19.942 - maxfilters 128
21:03:19.942 - caps 200304
21:03:19.942 - PossibleStart 1
03:21:30.685 - Start logging...
03:21:30.685 - GetBdaTunerList
03:21:30.685 - tuner Silicondust HDHomeRun Tuner 105287AD-0 -  -
03:21:30.935 -   Silicondust HDHomeRun Tuner 105287AD-0 ex:56781 type:DVB-C
03:21:30.935 - tuner Silicondust HDHomeRun Tuner 105287AD-1 -  -
03:21:31.196 -   Silicondust HDHomeRun Tuner 105287AD-1 ex:56782 type:DVB-C
03:21:31.196 - GetInfo 2
03:21:31.196 - CreateExtApi default
03:21:31.196 - MIS/PLP NOT supported
03:21:31.196 - GetModuleInfo {BDA} Silicondust HDHomeRun Tuner 105287AD-1 56782
03:21:31.196 - exIndex 1
03:21:31.196 - maxfilters 128
03:21:31.196 - caps 200304
03:21:31.196 - PossibleStart 1
03:21:31.196 - CreateModule 56782
03:21:31.196 - CBDAManager
03:21:31.196 - BDAManager::Start 56782
03:21:31.196 - index 1
03:21:31.196 - BuildGraph
03:21:31.206 - LoadNetworkProvider DVB-C
03:21:31.206 - System NetworkProvider!
03:21:31.206 - GetTunerSpace DVB-C
03:21:31.206 - DVB-C(C) SR: 6900
03:21:31.206 - put_SymbolRate: 0x0
03:21:31.206 - Connecting NetworkProvider -> Silicondust HDHomeRun Tuner 105287AD-1 ... ERROR!!!
03:21:31.206 - !!!BuildGraph error Cannot connect network provider
03:21:31.206 - TearDownGraph OK
03:21:31.456 - ~CBDAManager
03:21:31.456 - PowerOff
03:21:31.456 - Stop
Beat version does not work
Logs.zip
(7.94 KiB) Downloaded 204 times
Progdvb 7.16.09
Same error
19:28:22.604 - tuner Silicondust HDHomeRun Tuner 10529C64-0 -  -
19:28:22.926 -   Silicondust HDHomeRun Tuner 10529C64-0 ex:56781 type:DVB-C
19:28:22.934 - tuner Silicondust HDHomeRun Tuner 10529C64-1 -  -
19:28:23.255 -   Silicondust HDHomeRun Tuner 10529C64-1 ex:56782 type:DVB-C
19:28:23.260 - GetInfo 10
19:28:23.265 - CreateExtApi default
19:28:23.273 - MIS/PLP NOT supported
19:28:31.003 - GetModuleInfo {BDA} Silicondust HDHomeRun Tuner 10529C64-0 56781
19:28:31.009 - exIndex 8
19:28:31.021 - maxfilters 128
19:28:31.033 - caps 200304
19:28:31.046 - PossibleStart 1
19:28:31.057 - CreateModule 56781
19:28:31.069 - CBDAManager
19:28:31.081 - BDAManager::Start 56781
19:28:31.093 - index 8
19:28:31.106 - CreateExtApi default
19:28:31.119 - BuildGraph
19:28:31.138 - LoadNetworkProvider DVB-C
19:28:31.151 - System NetworkProvider!
19:28:31.191 - GetTunerSpace DVB-C
19:28:31.204 - DVB-C(C) SR: 6900
19:28:31.216 - put_SymbolRate: 0x0
19:28:31.230 - Connecting NetworkProvider -> Silicondust HDHomeRun Tuner 10529C64-0 ... ERROR!!!
19:28:31.253 - !!!BuildGraph error Cannot connect network provider
19:28:31.265 - TearDownGraph OK
19:28:31.396 - ~CBDAManager
19:28:31.403 - PowerOff
19:28:31.409 - Stop
