Trasponder frequency shift problem after channel search
Hello, can someone help to solve this issue?
I use an .ini trasponder list from kingofsat, starting search the channel in ProgDVB but the parameters finds are wrong.
The parameters are exactly one trasponder AFTER the one associated to a channel.
For example, a channel that must to be in TP 11919 ? After search in ProgDVB is set to 11938.
Btw the channel works with correct parameters instead the wrong set by ProgDVB after scanning.
I have deleted all channel list, all folder and reinstalled from zero progdvb but the problem remain the same.
Actually i use the latest version (7.17.02).
Somebody have the same issue?
