Re: Record after hibernation(SOLVED)
Prog wrote:Try select MS scheduler in scheduler settings of ProgDVB.
Hi!
Thats the scheduler I have used!
___
If I schedule a recording and put the computer to "sleep",then it starts and the screen is black-and it does not record the channel.
If I do the same,put it to sleep..and hear it start and the touch the mouse(or keyboard),..THEN it records?
It seems that the "complete" wakeup process does not work properly!
The screen must be on!..why?
I have now done some more tests.
Example:
1.I program ProgDVB to record at 11:50 to 11:52
2.I use another prog. to wake up the PC at 11:48
3.I uses VNC remoteprog.daily....I use that prog to login to my pc at 11:49,and just click on ProgDVB,and the logout.
4.And NOW it records the channel I want.No screen on,and it turn the pc off when its done.
I really thought that this function was working when I bought this prog.
Does the staff of ProgDVB have any solution for this?
----------- SOLVED -----------------
I solved it myself!
I used a small prog to wake the pc up from hibernation,and start ProgDVB!
So now I can shedule a channel,put the pc to sleep and it wakes an records the channel and then shuts down!
