Problem with NovaS Plus + ProgDVB
Hi,
iam new to this Forum and got a Problem:
I have got a Hauppauge Nova S Plus on an Asus A8V Deluxe. If I start ProgDVB this message came up:
Device not started: ((BDA) Hauppauge WinTV 88x DVB-S Tuner/Demod)
Connect TIF error
What can I do to solve this problem?
Thx for your support!
hi , as you can read in this forum 100 times...choose the bda device ...as for all cards running on bda drivers
please , next time use the search function first b;)
can not be ...
which OS do you use ?
works the original software with the card ...this must be done first...to test that the card is ok...
when this is done you can try 3rd party software like progdvb...
