Hi help please , read the forums and cant find any info, i bought this card (azurewave ad-sp400) and cant get it to work with progdvb ?. on their site it says works with progdvb ?. can get channels ,but takes about 5 mins to change channel, and wont work with HD . try to scan and it locks ,
anyone get this card working ? or do i throw it in thew bin .
using a core2due e6600, nvidea 8600gt 256mb, 2 gig ram, lg wide 22" monitor. specs should be ok ?.
thanks rkraw3.
Does it work with it's original software, completely?
What ProgDVB version(s) did you test it on?
Perhaps a slightly older one would work better?
As I don't know that device, does it's driver's .INF file mention any compatibilities at the end?
If any, try the search engine on those.
BDA or WDM driver used?
What's the complete device name in ProgDVB, device list?
Details rule
Details rule
Hi thanks for the reply, yes it works with its own software, HD picture is good normal pictures are iffy.. tried old and the latest progdvb, i can get a channel and lovely picture but cant scan or change channel ?. tried various codecs etc.. it is BDA drivers. it is dbs dtv-dvb mantis dvbs receiver 1.35 1.33.
thanks
rkraw3.
thanks
rkraw3.
Perhaps use our search function for mantis.
Some results will be in russian, but it's possible to machine translate to english by use of Babelfish on altavista.com.
Hi thanks for the reply, ok i read and read the forum and the russian one too, got the card working but no HD picture, i get epg, tried codecs graphs etc but still no hd, i know it may be a graph or filter problem ? but cant find out what. how can i use a graph made in graphedit in progdvb ?.
progdvb does not see the graph i saved ?..
many thanks..
rkraw3.
many thanks..
rkraw3.
The station you've tried on, surely is free TV?
Channel properties, if any ECM / EMM / crypt provider entry in there, it's crypted, not to be discussed here...
MPEG2 or h.264? In case of doubt, check at satcodx.com
However, you could make a recording, check file size growing a while, and after stopping and closing ProgDVB, try to open in another (HDTV compatible) player.
As you can see in my signature, my hardware won't allow me to use HDTV.
This for, someone else should continue here now, please...
Hi thanks for reply,s got card working good with 5.10 but no hd picture , tried all types of codecs but no picture. had free hd channels on older version but lots of lock ups ? . but atleast i can use the card now .
rkraw3
rkraw3
