Hi all, I saw many posts about Skystar HD but I wasn't able finding anything about my problem.
I installed ProgDVB and configured it for use the Skystar HD as Technotrend BDA/DVB-s Tuner. That works fine, I receive perfectly the standard channels, but there is no way to get the crypted ones. When I try to access the "CAM Interface" menu, I keep waiting but no cam is ever found (and when I close the window the app crashes). What can I do? Thanx for any help
I'm quite noob maybe I'm explaining it wrong... but I saw that the Skystar 2 (which is not compatible) has in the specs the CAM support. Isn't it what I need, but which isn't working with the Skystar HD?SiLencer wrote:afaik the ci is not supportet in progdvb
[edit] I mean, I got the CI slot, with a CAM inside (TRex)
this card has no ci ...but I saw that the Skystar 2 (which is not compatible) has in the specs the CAM support.
