dvb-s usb box recommendation
Hi there,
i am new at this stuff and want to know, which usb dvb-s box you can definitely recommend for using with progdvb?
I already owned a geniatech satbox and was very disappointed, as it worked somehow, but go only a few channels and a lot of problems. Friend of mine got the same box and it worked well. He tested mine and it got the same problems. I send it back, got another one, same problems.
So i am looking for an alternative solution.
Thanks for your attention
Greeting
