HVR 4000 DVB-S and DVB-T together
Hi,
is there a way to have DVB-S and DVB-T enabled together in progdvb? Because here i can receive different things on DVB-T and DVB-S so i really would like to switch between them dynamically.
But the only way i found is to disable one of the BDA devices in the device list and enable the other (which is kinda frustrating).
Can i bind specific channels to specific devices and have them enabled as needed?
Thanks
Yes, you can enable both devices (in free version also). But I am not test this function on 4000. It can be depended from hardware and driver.
Hi,
i doesn't seem to work, i got 4 devices in my device list
{BDA} Hauppauge WinTV 88x DVB-T Tuner/Demod
and
{BDA} Hauppauge WinTV 88x DVB-S/S2 Tuner/Demod
On time with File Name anysee.Device and another time with BDA.Device
The anysee.Device doesn't seem to work anyway, from the BDA.Device it seems i can enable one alone just fine.
But when i try to activate both, i get the error: "Run DBA graph error", and then Device not started (with the name of the device i try to start).
The device then has a card symbol with an X.
So it seems only one at a time works.
Same thing here with HVR-3000.
anysee devices doesn't work at all, and BDA devices I can enable only one at a time.
Is it because this is hybrid card, or poor BDA drivers?
And still no Hauppauge remote support....
OK, I am using BDA.device, but why I can't use both DVB-s and DVB-t devices??
When I select one, second is disabled. Is this because card is hybrid?
Few weeks ago I asked about IR support for Hauppauge...
Is there any progress with this piece of your fabulous software??
