Hello,
I'm trying to get ProgDVB 5.14.3 (32-bit) to work with the DTV2000 H card. One of the issues I'm experiencing is that ProgDVB seems to lock up soon as I run it after install. The program either stops responding all together, or runs very slowly, responding to mouse clicks every 10 seconds. And when I manage to tune the card and populate the channel list on the left, the software crashes every time I want to watch the channel. I tried changing DirectShow settings to various decoders (ffdshow, nVidia Pure Video, Leadtek Video decoder, etc), still the same stability problem. Sometimes I get sound then a few frames, then crash.
I'm running Windows XP x64. I tried the 64-bit version of ProgDVB and I'm getting the same issues as above, plus additional codec problems, as ProgDVB is unable to render via 32-bit codecs.
I'm only tuning into free to air terrestial channels in Australia.
Ok I tried it with the 32-bit version, but ProgDVB still stalls on load. It locks upand occasionally responds to mouse clicks every 10 seconds, just like before.
Are the any logs I can give you to aid problem solving?
