Wintv-hvr-3000
Hi , i'm using wintv-hvr-3000 with latest progdvb (free version) . everytime i open progdvb , its says "no device found" . but when it open , it works fine for few mins (play all channel ) without any new config in "device" section !!! then it gives a error n closed . what i'm doing wrong .
i'm only using dvb-s no dvb-t .
Thx a lot
@Prog
Thx a lot for ur reply sir . here i have tried to post the screen shot :
when i try to run progdvb , it says no device :
when It run , work great :)
Now i went to device list to check , seems everything okey :
But after few mins it gives a error n close :(
The Os sytem : xp sp3 , but i dont have any internet connection to this computer .
Can u please help me . Thx a lot for ur time sir.
@ prog
I think u may also need to know this (as u mentioned ).
I have only single plugin . Before progdvb i used wintv application (i remove it n reboot computer before installing progdvb ) . Wintv application had no problem with finding hardware . I also installed k.lite codec pack . After the error , when i press "dont send report(to microsoft)" , progdvb close immidiately . when i rerun the program , it gives option "keep last good config" n other two . I think this mean , progdvb was not close properly during the error . I have very poor memory in my computer , only 512 MB .
Thx again for ur time .
