is pinnacle pctv 310e compatible with progdvb?
in version 5.15.2 is auto-detected as
{BDA} DTV-DVB USB Hybrid Digital
but i can't scan any channels.
it's the same with version 4.62.6
system
intel core duo T2400 with winxp sp3
original card software installed
just tell me if someone could get this card to work with progdvb. if it has worked for someone i'll try figure out the problem.
pinnacle hybrid pci 310i not working
#6I bought the pinnacle hybrid pci 310i but also have trouble getting it work.
when setting the analog tuner properties I get an error:
cannot connect to base filter (bindtoobject), pinnacle mpeg2 layer encountered an error.
the DVB-T tuner doesnt generate an error but it couldn't find a channel.
did anyone succeeded making this card work? it has a 713x tuner.
Thanks for your help.
Re: pinnacle hybrid pci 310i not working
#7I 've this card and i have only problem with analog tuner similar your error. I don't solve it and i waiting a new version of ProgDVB.bricolux wrote:I bought the pinnacle hybrid pci 310i but also have trouble getting it work.
Currently i use version 5.16.2 and i use only this drivershttp://cdn.pinnaclesys.com/SupportFiles ... mePCTV.htm
With new XP installation i don' t install the TVCenter suite: i' ve installed only the drivers and for DVB-T decoding only use Dscaler5.
Work fine but sometime i have a problem in video overlay that audio not sincronized with video (only video overlay.... in the file recorded the a/v are OK)
(Excuse me for my English)
bye
#8Same configuration but with version 6.01.01 the problem isn' t so evidentOmihalcon wrote: Work fine but sometime i have a problem in video overlay that audio not sincronized with video (only video overlay.... in the file recorded the a/v are OK)
bye
