I've had to download and instal ProgDVB but SkyStar2 is not accepted although its in the Device List. The error message says 'Device not started
(BDA - no device)'. At first I could delete the error message and the program ran OK but now the program is frozen.
I downloaded and installed DVBDream, as a standby to Prog, and that works correctly.
What should I try next?
#3[quote="Prog"]You must install last version of ss2 driver.[/quote]
AHa. SS2 must have been in memory from before my PC crash.
I have downloaded the latest version of ProgDVB and the SS2 driver,
but I've had to re learn how to install the SS2 driver into windows.
I'm now up and running again
Thank You.
Thank You.
