If not using it, you may want to take away the file "empgpdmx.ax" from the "Filters" sub folder.
If using timeshift in RAM, you may want to reduce the buffer size, to avoid it to expand into the swap file. Or switch to timeshift in file, or reinstall without timeshift.
Also look for CPU load and memory use.
See, we don't really get a lot of details from your message.
Perhaps you also did not, from (BTW, what?) Windows...
hi again.
how can I unistall or erase the timeshift, in the options of installation dont show up and in the progdvb I cant find anything like erase timeshift or dont use timeshift, just the progdvb give me the option of use the ram or use a file as bufer timeshift.
Hauppauge Nexus
ProgDVB 4.56.2
XP Sp2
2GB Ram
Dual COre 2.8ghz
You chose that at installation time.
