ProgDVB why not work with Hauppauge WinTV Express
http://www.hauppauge.fr/pages/products/ ... press.html
see video here
http://www.berbez.powa.fr/Sans%20titre_ ... 0titre.wmv
all the errors I see in your video, are about mpeg2 codec's.
can you play any mpeg2-video on your computer? in any program, like windows-mediaplayer?
if you can, take a look at your ProgDvb settings tab Video. Is the field right of MPEG-2 filled in correct?
If not, then install a mpeg2-codec. it mostly comes with some video- or DVD- player program.
The second thing to do next, is to ad a LNB in ProgDvb: go to - DISEqC and Profiders in the Settings -menu.
(Oh: The video in your last post is in wma, not a'n mpeg.)
Pentium IV 3.0 GHz, 2GB DDR2;
Win XP mediacentre SP2, ProgDvb 6.01, Digital TV 3.4;
Twinhan DVB-S CI PCI [AD-SP300 (1034) ver:1.2 Mantis];
-&- Driver: "MantisDriver_V1.1.0.400"
-&- Official "Canal Digitaal" Cam and Smartcard;
Technisat Skystar 2 TV PCI;
-&- Driver: 4.5.0.0
2x1 DiSEqC Switch;
Inverto Silver Tech 0.2dB Single Output LNB @ Astra 23,5';
...LNB @ Astra 19,5';
78cm Triax;
-&- Driver: 4.5.0.0
2x1 DiSEqC Switch;
78cm Triax;
ok thank you have more problem of codec mpeg2.
but I do not find my chart in device list
Hauppauge : WinTV-Express
Modele : 44xxx
Catagorie: Basic Analogue
Modele : 44xxx
Far as far as I remember from youre video, the two devices you selected, dit "start"!
now I take a closer look, I notice it's an analog tv-tuner card?
My french is ver poor, but I noticed something about mpeg1.
All togther, I 'm not so sure anymore...
Have you tried the manufacterers software? houw about that?
-&- Driver: 4.5.0.0
2x1 DiSEqC Switch;
78cm Triax;
-&- Driver: 4.5.0.0
2x1 DiSEqC Switch;
78cm Triax;
sorry I do not speak l' English: (
I must download the version freeware?
manufacterers
manufacterers
mine isn't very good to, But what I mean is, how Juergen say's it:
"- how does another software (/version) behave, including the original one that came with the card"
-&- Driver: 4.5.0.0
2x1 DiSEqC Switch;
78cm Triax;
-&- Driver: 4.5.0.0
2x1 DiSEqC Switch;
78cm Triax;
the manufacturer ~ le manufacteur = le fabricant...bean wrote:manufacterers
No, I don't speak nor read French, but Babelfish may be pretty helpful.
Anyway, you will in fact find MPEG2 codecs in your DVD player software, or inside of the original DVB application.
Codecs come as *.ax files.
Copy those to the "Filters" subfolder, edit the file "Register.bat" to their names and then run it, to make the codecs available for ProgDVB.
OK I set up the codec mpeg2!
regsvr32 /s LC.dll
regsvr32 /s em2vd.ax
regsvr32 /s el2ad.ax
regsvr32 /s elaudec.ax
regsvr32 /s Mpeg2DecFilter.ax
But my card(map) and not in the list Here is my card(map)
http://www.hauppauge.fr/PDFs/755.pdf
regsvr32 /s LC.dll
According to that data sheet, the original software and / or device only support MPEG1 and DivX.
Maybe that's the reason, why ProgDVB does not recognize this analogue interface properly. Like it won't work with my FAST AVMaster, pure MJPEG hardware.
