Hi Guys:
i have installed my skystar 2.8 with 4.5.1 driver and with BDA folder but when i start ProgDVB 6 (64bit) at windows 7-64 bit ,i recieve these errors
http://kimag.es/share/35217358.png
http://kimag.es/share/45519024.png
Re: problem in ProgDVB 64 bit
#2Do you installed ProgDVB with Admin Mode ?worldclass wrote:Hi Guys:
what is admin mode?
i installed skystart manually from device manager and selected file from BAD folder
With Windows 7 you are a normal user, and should install software as a Administrator.worldclass wrote:what is admin mode?
Look at Google, how to become an Administrator.
now i installed ProgDVB 6 standard version (not 64 bit) and i can enable BDA
according to the picture
is my problem solved?!
wouldn't be any problem with this version on windows 7 -64 bit?
http://kimag.es/share/2910932.png
looks good...now i installed ProgDVB 6 standard version (not 64 bit) and i can enable BDA
