Hi
Can someone help me, im going crazy. I purchased a prof 7300 redline because my old card was not dvb-s2 compliant, I had read good reviews of this card and was told it was compatible with prodvb.
The card will not scan any hd dvb-s2 channels at all but does seem to get a lock I think, every transponder I have tried.... no luck. It works fine on regular dvb-s channels.
Ive tried the most up to date driver and the last driver availible, no luck, even tried different versions of progdvb.
I'm using win 7 x86 32bit.
Help is much appriciated.
Thanks
Thanks prog for the quick reply.
I did a manual transponder scan and found that If I set roll off to .35 and pilot to off I pick up some hd channels and they worked.
The problem now is its not picking up all hd channels, im getting a red icon beside a lot of the channels its scanning, its not the scrabled channel icon, its another red icon?
Thanks
Thanks
Then let people know what tha other red icon looks like.
For example, if it looked like a diskette, this would stand for a channel without audio nor video ID, obviously a data service then.
Not all signals on DVB-S2 transponders have to be TV services...
