Hi
i have skystar 2 usb and i install the driver came with cd then
i install progDVB 6.42.6 Std and i go to devices and enable skystar2 then i close and open again it gives me message
"skystar2 device not started" !!!
any idea which version of the program works well with skystar 2 usb and which driver version works well with the program ?
thanks in advance.
Re: skystar2 usb device not started
#3thanks for reply
what do you mean by WDM driver ?
do you the utility used to open the channels? or what?
#4this ->what do you mean by WDM driver ?
There are two driver modells avivable for many cards ...and i install the driver came with cd
WDM -> http://en.wikipedia.org/wiki/Windows_Driver_Model
The card/box is shown as network device in windows device manager
BDA -> http://en.wikipedia.org/wiki/Broadcast_ ... chitecture
The card/box is shown under ´audio/video/game controllers´ in windows device manager
so the precise question should be ...what kind of driver did you install ?
#5hiProg wrote:Do you use WDM driver? You must install software also.
where i can Download WDM Driver
