Hi,
I have an Terratec Cinergy S2 HD PCI CI on a Windows XP SP3-system.
Progdvb is version 6.46.6 Pro (registered).
As already stated in the forum, i chose the BDA-Driver with "Azurewave/TwinHan"-option.
Unencrypted stations work fine, but encrypted stations only show up blank.
Using the standard Terratec-software also encrypted stations work work fine.
When i start Progdvb in debug-mode, the video and audio-PID of encrypted stations show an zero bitrate.
ProgDVB is run as administrator and the correct ECM is chosen.
Do you have any suggestions, what might be the problem?
Florian
Re: Terratec Cinergy S2 HD PCI CI - CAM not working
#2Current version ProgDVB not support CI for Terratec.
