Re: progdvb 64bit problem
It doesn't work for me. because the software (progdvb 64bit) support skystar2 driver (v1.31) not the latest driver (v4.6.0) ,and where i can find (Sky2PCAVSrc.ax). besides the software (progdvb 32bit) work fine with some problems with channels signal of the program sometimes disappear. i used another program (DVB Dream v1.5e) and it work fine with me. but i prefer (progdvb 64bit).
This is a source filter file, that's required for your device.
When used with a 32 bit application, it would have to be a 32 bit version of that file. Like for a 64 bit application you would be in need of a 64 bit version of that file.
I used Prog Finder v2.24 (64bit) with BDA driver. i have this result:-
Description:
Stopped working
Problem signature:
Problem Event Name: APPCRASH
Application Name: ProgSatFinder.exe
Application Version: 2.23.0.0
Application Timestamp: 4caf4278
Fault Module Name: KERNELBASE.dll
Fault Module Version: 6.1.7600.16385
Fault Module Timestamp: 4a5bdfe0
Exception Code: e0434f4d
Exception Offset: 000000000000aa7d
OS Version: 6.1.7600.2.0.0.256.1
Locale ID: 9217
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid= ... cid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
So the problem is in your software that it doesn't compatible with any system (64bit), and also progdvb (64bit), and i send message to TechniSat Support, and they wrote this to me :-
Dear Mr. Ali,
thanks for your reply.
Like I said in my first mail we can't give any support for other software than
the DVB Viewer.
[skiped][
