Hi all!
I am having the problem that ProgDVB only plays any channels on diseq position 1 on position 2,3 and 4 it finds channels and get signal but quality = 0 and no picture or sound.
Some details Windows 7 X64 Ultimate, latest drivers and TBS.eBDA from http://www.tbsdtv.com/, SPAUN SAR 411 F Diseqswitch and ProgDVB version 6.63.6 , 6.63.7 and 6.63.8 x32.
I have checked and tried different settings under Settings / Deviceoptions.........
With the TBS.eBDA that comes with the program does the cards not even start.
The setup works with other DVB program........
Any ideas ?
Re: TBS 6921 and TBS 8921 probably Diseq problem.
#2Try install at first without any addition module. Only last version of ProgDVB.
Also check params in Settings->Device options.
#3Hi !
I did an completely new clean install of the latest ProgDVB version 6.63.8 no added modules and no extra and the result is that the card does not start ............as seen in the submitted screencap and the Settings->Device options is not reachable.
but if I replace the original TBS.eBDA with the one from http://www.tbsdtv.com/ then i can add my Diseq switch and satellites BUT I only get any picture on channels on satellite pos 1 .....on satellite position 2,3 and 4 all channels is found and get signal but quality = 0 and no picture or sound.
Best Regards.
/Anders
Best Regards.
/Anders
#4Do you test ProgDVB x32? Try install not in program files.
#5Hi!
I installed ProgDVB version 6.63.8 X32 in C:\progdvb and the result is exactly the same as before........
I borrowed an Hauppauge HVR-4400 from my friend and this works ok on all 4 satellite positions.....
Best Regards.
/Anders
Best Regards.
/Anders
#6What error message you have on start of ProgDVB?
#7Hi !
Sometimes when i playarund with the program depending on what TV-Source i have chosen when i start the program it says it´s missing adpsi30.dll and dwusbapi.dll only with the TBS.eBDA from program not from the TBS web and it seames to have started wit ProgDVB version 6.63.8.
Best Regards.
/Anders
Best Regards.
/Anders
