HW: Hauppauge HVR 3300 DVB-S
most recent driver.
SW: ProgDVB 6.80 64x (installed in a different folder)
Windows 7 64x
ProgDVB shows two sources {BDA} Hauppauge WinTV 885 ALT BDA Tuner...
and {BDA} Hauppauge WinTV 885 BDA Tuner...
The "ALT" is the right one for DVB-S but doesn't work sometimes. Checking and unchecking will make it work after some time.
Until it works it shows the error
"[{BDA} Hauppauge Win TV 885 ALT BDA Tuner/Demod] Device not started!"
Then again, starting the program, sometime it works, then again not.
Any suggestions???
Thank you!
[solved] Hauppauge HVR 3300 device not started
