I bought this Sabrent TV-USBHD ATSC NTSC dongle tuner some time ago, works with Blaze software which is honestly pretty buggy and lame. Thought I'd give ProgDVB a try, unfortunately things aren't quite working.
The software selects a BDA Microtune as the device which appears to be partially correct, the device's active light comes on. The Microtune name is consistent with what Windows XP installs when the device is first plugged in. The ProgDVB scans for channels, and finds none. I know this isn't correct, as there are 10 channels available via the Blaze software.
I've done a little searching in regards to the chipset, but it not clear to me what it uses. I'd have to crack open the dongle.
Anyone have any thoughts or suggestions?
David
Re: Sabrent TV-USBHD
#21. Try select other mode in Device Options of ProgDVB.
2. Try Channel list-> Manual scanner.
#3Tried as many variations that I could find, of which there are a lot.
Used the frequency of a known station, and tried lots of subsettings.
No luck. Any other thoughts?
David
David
#4Try select MS mode and change "use tuner request". Also possible "symbol rate in khz"
#5Well having tried various Manual Searches, and Blind Searches, and assort symbol rates, I'd say this card isn't compatible.
Shame.
Thanks
Shame.
Thanks
