Re: Avermedia Volar Green HD USB A835 USB Remote ?
HI! Thanks for this thread I want to post here my settings for the RM_KS remote that comes with AVerTV Volar HD Pro. Thanks to the instructions provided by AVerLIRC (https://sourceforge.net/projects/averlirc/) I could customize one of the .reg files to suit the RM_KS remote then I used in conjunction with EventGhost, it works perfectly. Be sure to temporarily disable AverQuick tray utility in case of averlirc. Thanks again for this information, thanks a lot.
(Win 8.1 x64)
Sorry but I wasn't be able to upload the .reg file, cut and paste the following in a new text file with .reg extension and merge into the registry.
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\AVerLIRCService\Remote]
@="RM_KS"
"1"="POWER"
"55"="SOURCE"
"41"="DISPLAY"
"52"="CH_RTN"
"21"="SNAPSHOT"
"51"="PREVIEW"
"29"="CHANNEL_UP"
"30"="CHANNEL_DOWN"
"27"="VOLUME_UP"
"28"="VOLUME_DOWN"
"53"="FULLSCREEN"
"26"="MUTE"
"43"="AUDIO"
"4"="RECORD"
"8"="PLAY"
"5"="STOP"
"58"="PAUSE"
"6"="REWIND"
"7"="FORWARD"
"9"="GREEN"
"10"="BLUE"
"14"="EPG"
"54"="AUTOSCAN"
"31"="0"
"32"="1"
"33"="2"
"34"="3"
"35"="4"
"36"="5"
"37"="6"
"38"="7"
"39"="8"
"40"="9"
