Please add support for
Twinhan Starbox II usb 2.0 HDTV
(STARBOX VP-7021A DVB-S, BDA, USB 2.0)
http://www.tomshw.it/guides/consumer/20 ... box-01.jpg
http://www.twinhan.com/download_driver&software.asp
Thanks
Re: Twinhan Starbox II usb 2.0 HDTV
#2Hi dude ,I've the same card like yours ,but I have a problem with progdvb (cannot start device) even when I installed the BDA drivers still got the same problem ! can you suggest me something ?MK wrote:Please add support for
Thanks
thanks in advance .
same problem with me
working only on MyTheatre
I think that ProgDVB can't send the power on command to the StarBox-II. the only solution I found it that you can run the Twinhan SW to start the device and exit it. then you can start ProgDVB and it will work fine.
hope a full support for StarBox will be there soon
Another vote of support for the Starbox II.
I can't use ProgDVB with it at the moment even with the BDA driver.
Pleaazze
Pleaazze
Well i have my STARBOX ii and works flawlessly .Lucem wrote:Another vote of support for the Starbox II.
Pleaazze
I use {BDA} DVB-world-S.device (BDA.Device) ver 1.18
Hey SkyWatcher, that is good news.skywtcher wrote:Well i have my STARBOX ii and works flawlessly .Lucem wrote:Another vote of support for the Starbox II.
Pleaazze
I get a "{BDA} Local DVB-T Digital Antenna) Device not started message when startint ProgDvb.
Where did you get your drivers from ?
Can you link me ? Please.
Thanks
download and setup software in this link then setup ProgDVB and it will work but you may have some little problems
It seems to work with these driver but if it is changed channel goes in crasch. unfortunately it works well only with DVBdream.
There is a check box in satellite setup, distinguish by frequency - uncheck it and it will not crash.MK wrote:It seems to work with these driver but if it is changed channel goes in crasch. unfortunately it works well only with DVBdream.
Use The driver that exist in Twinhan site with ProgDVB version 4.62.6 and choose Twinhan Compatible and it will work very fine
#15
I can't get the Starbox II to work with ProgDVB at all! I tried both ver. 5 and 4.88 and it either comes up and freezes or crashes! It seems totally worthless, does anyone know how to get it to run? Which box do you select if the Starbox II isn't listed?
