Problem with ADS Tech
Hi all,
i buyed the Card ADS Tech - Instant TV DVB-S, but he works not. At some devices, i have rejection without receiving, or the device don't starting or progdvb crashes.
All driver are installed, the original Software works middling.
Thanx for any help
SiLencer wrote:As you can read in the old Forum the ´KWorld DVB´ Device should do the job ...
I did search before posting, and found many threats about KWorld and ADS. So, i knew this tip.
Kworld card is started, But can't do anything in Diseqc window!
so, what now?
Does that card act as a BDA device?
If so, bad luck, no DiSEqC with ProgDVB (ATM?).
BDA drivers require unknown dirty proprietary tricks for DiSEqC.
Supposingly ProgDVB can just hope, solutions may one day get public.
Support from manufacturers and / or MS seems to be far to expensive resp. unavailable.
Else, no idea.
Juergen wrote:Does that card act as a BDA device?
Else, no idea.
Yes, unfortunately this card is a great BDA device. Sorry prog, progdvb is a very good program, works fast and without bluescreens in our office. But on my PC, i deinstall progdvb and use now dvbdream. After install, the device was found without problems...
