AVerTV CaptureHD(H727) analog
Hi there,
I try to use ProgDVB with my AVerTV CaptureHD(H727) Card,
but I couldn't get it working...
I'm using only the analog TV.
In the 64-bit version I could not activate the checkbox "Analog TV" while the installation dialog.
In the 32-bit version it could activate the checkbox, but when I try to select the Avermedia input device, it's empty.
I'm using Windows 7 SP1 x64.
Is there a solution for this problem?
best regards!
