Hi, I have a DigiVox Mini III usb stick and tried a new versions of ProgDVB, but it can't start the stick. There is no Quality and all new scanned TV Stations are lost. But if i start DVBViewer, use the DVB stick, close DVBViewer and start ProgDVB, the Stick works.
I used Version 6.60.0 a long time, because it worked best for me.
edit: I use Win7 64bit, i3 1155
DigiVox chip, driver: Afatech AF9015
edit2: I jus found out, that my tv captures with my hauppauge HD SE2 are corrupted on some positions, so I can't use a new version of ProgDVB, pretty disapointing.
Re: DVB-T USB Stick doesn't start
#4Try change Settings->Device options. Also try start ProgDVB with admin rights.
