compatibility
I live in Spain ,and have a IRIS receptor and a canal + antenna, wich is a decoded pay service
I will like to know :
-if the receiver works with PROGDVB
- IF i CAN SEE PAY CHANNELS, like canal+
- if not what receive I need to buy
thanks for a prompt answer
Re: compatibility
Prog wrote:I think impossible connect IRIS receptor to PC. But you can install and test.
The iris is conected to a TV set philips ans a have a local network and ext antenna
what I mean is wich software can I use to get better result on satellite
thank you
