Hi
I Would like to Design a New Plugin for ProgDVB
The Intended Plugin will Deals with Channels So,
Is There any API I Can Talk To, to Change Channels into ProgDVB ?
If There is Any SourceCode Of Plugins For ProgDVB Please Provide The link.
Any Help will Be Apperciated
Bye
Hi Prog and Thanx For the Reply
As ProgDVB became a popular Program and I mainly use it
i need to do more functions that suite my needs so i need
more help
well, i have found some declarations in the API page
1- #define PROGAPI_SET_CHENNEL 0x01022004
2- #define MDAPI_SET_PROGRAMM 0x01020011
what i percisly want to do is a simulation
of clicking on a channel
in the channels list which makes it to be viewed.
in other words a callback function that calls and view the channel by it's No.
which one of the previous Declarations could be used to achieve that
any help will be appreciated
PS:
at last i think it would be useful if the site has some examples of Plugins
that could help ProgDVB to be in the lead worldwide .
so keep it on Prog , you really done a great job with this creative program.
Bye
more help
PS:
Bye
