Re: Телеканалы не работают
Prog wrote:Включите пожалуйто логи (Options->Debug->Logs) и пришлите после следующего такого сообщения все файлы из Logs
17:50:49.124 - Start logging...
17:50:49.124 -
17:50:49.155 - Start engine 6.200
17:50:49.155 - ExceptionFilter::Init. restart=1
17:50:56.425 - DevicesManager::Start
17:50:56.425 - CAVManager::Init
17:50:56.725 - CAVManager::Init defCodecs 0
17:50:56.745 - CAVManager::Init defCodecs 1
17:50:56.745 - CAVManager::Init defCodecs 2
17:50:56.775 - CAVManager::Init defCodecs 3
17:50:56.795 - CAVManager::Init defCodecs 4
17:50:56.795 - CAVManager::Init defCodecs 5
17:50:56.816 - CAVManager::Init defCodecs 6
17:50:56.836 - AV settings loaded
17:50:56.856 - VR: GUI
17:50:56.866 - AV:UpdateAudioProcessor spec=0 agc=0 bands=0
17:50:57.547 - AV:UpdateAudioProcessor spec=0 agc=0 bands=0
17:50:57.547 - AV:UpdateAudioParamsAfterActive
17:50:57.557 - AV:UpdateAudioProcessor spec=0 agc=0 bands=0
17:50:59.179 - DevicesManager::StartDevices...
17:50:59.189 - device netclient.0 17:50:59.329 - dev: Created netclient.0 018942F8
OK
17:50:59.329 - Api2BaseModule.GetAdditionInfo
17:51:03.936 -
17:51:03.936 -
17:51:03.946 - ########################### Mark of start channel changing.###########################
17:51:03.946 -
17:51:03.946 - GraphManager::MainChangeChannel 1+1 1 provs
17:51:03.956 - ----------- 1
17:51:03.956 - ----------- 1-a
17:51:03.956 - ----------- 2
17:51:03.966 - ----------- 2
17:51:03.966 - DevicesManager::DestroyAllTransponderManagerUsedForSetTransponders
17:51:03.976 - SetChannelLogic::SetChannel 0
17:51:03.976 - SetChannelLogic::SetNormalChannel
17:51:03.976 - SCL ---1
17:51:03.986 - SCL ---2
17:51:03.986 - SCL ---3
17:51:03.986 - SCL ---4
17:51:03.996 - SCL ---5
17:51:03.996 - SCL ---6
17:51:03.996 - DevicesManager::CreateCloneDevice
17:51:04.006 - DevicesManager::CreateCloneDevice OK - founded in list
17:51:04.006 - TransponderManager
17:51:04.006 - CTransponderManager::InitOnNewDevice 0189B88C
17:51:04.016 - N -> Incoming Stream Cache
17:51:04.016 - TrafficProcessingScheme_CreateForNewEngineTransport 1 ss=0
17:51:04.026 - Normal TsInputTrafficProcessor.
17:51:04.056 - FilterManager::InitOnNewDevice 1
17:51:04.056 - TS router+MarkerFinder -> InputTrafficProcessor
17:51:04.066 - Incoming Stream Cache -> TS router+MarkerFinder
17:51:04.066 - InputTrafficProcessor -> Router to timeshift
17:51:04.066 - InputTrafficProcessor(FM) -> FilterManager
17:51:04.076 - ModuleList::Free
17:51:04.076 - Api2BaseModule::GetCurrentDeviceInfo
17:51:04.086 - ModuleList::Load C:\Program Files\ProgDVB\Modules\PidRecorder.module OK
17:51:04.086 - Api2BaseModule::GetCurrentDeviceInfo
17:51:04.106 - ModuleList::Load C:\Program Files\ProgDVB\Modules\ProgMediaServer.Module OK
17:51:04.106 - ChannelGraph5.CChannelGraph5
17:51:04.106 - TransponderManager::AddChildChannel
17:51:04.116 - TimeShift.TimeShift
17:51:04.116 - TimeShift.Create 200 mbytes
17:51:04.126 - ts:One channel
17:51:04.126 - HugeMemoryBlocksManager::GetBlock 200 mbytes OK
17:51:04.126 - TransponderManager::CreateTimeshiftBuffer OK
17:51:04.186 - TimeShift.CreateReadingCursor
17:51:04.196 - TsInputTrafficProcessor.AddChannel 0
17:51:04.206 - SetChannelLogic::LookDeviceWithoutChannelsOrCloneAndMakeGraph
17:51:04.206 - ----------- 3
17:51:04.206 - ----------- 4
17:51:04.216 - ----------- 5
17:51:04.216 - ----------- 6
17:51:04.216 - ----------- 8
17:51:04.226 - ----------- 9
17:51:04.226 - ChannelGraph5.SetActiveState 1
17:51:04.236 - TransponderManager::SelectChannel
17:51:04.236 - TsInputTrafficProcessor.SelectChannel 0
17:51:04.236 - Api2BaseModule.UpdateAllOpenedChannels 0
17:51:04.246 - AV:UpdateAudioParamsAfterActive
17:51:04.256 - AV:UpdateAudioProcessor spec=0 agc=0 bands=0
17:51:04.256 - Graph::SetAudioChannelMask
17:51:04.266 - ----------- 10 04F9E350 01A15044
17:51:04.266 - ----------- 11
17:51:04.276 -
17:51:04.276 - TransponderManager::SetTransponder (CH) 0 1+1
17:51:04.276 - switching in SetTransponder time
17:51:04.286 - --SwitchEngineTransport TS > ITV
17:51:04.286 - PreScanner.Stop
17:51:04.286 - GraphState: Undef by PreScanner.Stop
17:51:04.296 - Incoming Stream Cache -> 0
17:51:04.306 - ModuleList::Free
17:51:04.346 - TrafficProcessingScheme_CreateForNewEngineTransport 2 ss=1
17:51:04.356 - InputTrafficHelper -> ITV2Timeshift
17:51:04.356 - TS router+MarkerFinder -> InputTrafficHelper
17:51:04.356 - Incoming Stream Cache -> InputTrafficHelper
17:51:04.366 - TrafficProcessingScheme_OnSetChannelOrTransponder ch=43981
17:51:04.366 - TimeShift.Reset
17:51:04.376 - TimeShift.Cursor reset
17:51:04.376 - ReaderCursor::Reset.. OK
17:51:04.386 - Prereader.Reset ...-OK
17:51:04.396 - TimeShiftBuffer.SetContentLenght TimeshiftOverNetModule disabled req=0 size=209715200
17:51:04.396 - TimeShift.Cursor SetChannel pidmask=00000000 first=1
17:51:04.396 - TimeShift.Cursor SetChannel::v 0 (0)
17:51:04.406 - ReaderCursor::SetChannel.. OK
17:51:04.416 - ReaderCursor::SetPosition 0 (w=0)
17:51:04.416 - Prereader.SetChannel..
17:51:04.416 - Prereader.SetChannel unmask 1
17:51:04.426 - Plugin::SetChannel 43981
17:51:04.426 - TransponderManager::SelectChannel
17:51:04.436 - Api2BaseModule.UpdateAllOpenedChannels 1
17:51:04.436 - GraphState: Undef by StartChannelIsReady
17:51:04.436 - PreScanner.StartChannelIsReady net=1 parseall=1
17:51:04.447 - GraphState: RequestTransponderMark by StartChannelIsReady ITV
17:51:04.447 - --SwitchEngineTransport end
17:51:04.447 - *Transport ITV
17:51:04.457 - TS router+MarkerFinder -> InputTrafficHelper
17:51:04.507 - Api2BaseModule.EngineApi_ChList_SendSubChannels 0/3
17:51:04.507 - Api2BaseModule.OnTunerStateChanged Connecting
17:51:04.597 - Api2Device::SetChannel result OK
17:51:04.597 - TrafficProcessingScheme_OnSetChannelOrTransponder ch=43981
17:51:04.597 - TimeShift.Reset
17:51:04.607 - TimeShift.Cursor reset
17:51:04.607 - ReaderCursor::Reset.. OK
17:51:04.617 - Prereader.Reset ...-OK
17:51:04.627 - ----------- 12
17:51:04.627 - CChannelGraph5::StartChannel 1+1
17:51:04.637 -
17:51:04.637 - #################### Start stream. (0.701ms) #######################
17:51:04.647 -
17:51:04.647 - TimeShift.Cursor SetChannel pidmask=00000000 first=1
17:51:04.647 - TimeShift.Cursor SetChannel::v 0 (0)
17:51:04.657 - ReaderCursor::SetChannel.. OK
17:51:04.667 - ReaderCursor::SetPosition 0 (w=0)
17:51:04.667 - Prereader.SetChannel..
17:51:04.677 - Prereader.SetChannel unmask 1
17:51:04.677 - Plugin::SetChannel 43981
17:51:04.677 - TransponderManager::SelectChannel
17:51:04.687 - Api2BaseModule.UpdateAllOpenedChannels 1
17:51:04.687 - GraphState: Undef by StartChannelIsReady
17:51:04.697 - PreScanner.StartChannelIsReady net=1 parseall=1
17:51:04.697 - GraphState: RequestTransponderMark by StartChannelIsReady ITV
17:51:04.707 - ChannelGraph5.CreateGraphForOsdOnly
17:51:04.807 - CChannelGraph5::CreateRender 6
17:51:04.807 - Graph::SetVideoRect {8 8 712 568}
17:51:04.817 - ----------- 13
17:51:04.817 - ChannelGraph5.SetActiveState 1
17:51:04.827 - Graph::SetVideoWindowRect {33 0 166 100}
17:51:04.837 - Graph::UpdateRenderMode
17:51:04.847 - GraphManager::MultiChannelRendering
17:51:04.857 - ChannelGraph5.SetActiveState 1
17:51:04.887 - Graph::SetVideoWindowRect {42 0 474 324}
17:51:04.967 - ----------- 14
17:51:05.248 - OK. 102
17:51:06.389 - * s:0 q:0 tr=0 (0) Connecting
17:51:07.140 - OSDManager::Window_Add
17:51:07.150 - OSDManager::Window_Show
17:51:07.261 - * s:0 q:0 tr=0 (0) Connecting
17:51:07.271 - OSDManager::Window_Show
17:51:07.301 - OSDManager::Window_Show
17:51:07.821 - OSDManager::Window_Show
17:51:07.831 - OSDManager::Window_Delete
17:51:07.942 - * s:0 q:0 tr=0 (0) Connecting
17:51:08.472 - Api2BaseModule.OnTunerStateChanged Playing
17:51:09.384 - * s:0 q:0 tr=0 (0) Preparing
17:51:10.385 - * s:0 q:0 tr=0 (0) Preparing
17:51:11.176 - OSDManager::Window_Add
17:51:11.186 - OSDManager::Window_Show
17:51:11.196 - OSDManager::Window_Show
17:51:11.386 - * s:0 q:0 tr=0 (0) Preparing
17:51:12.388 - * s:0 q:0 tr=0 (0) Preparing
17:51:15.893 - Graph::SetPictureParams
17:51:15.903 - Graph::SetPictureParams
17:51:16.494 - OSDManager::Window_Show
17:51:16.504 - OSDManager::Window_Delete
17:51:16.524 - * s:0 q:0 tr=0 (0) Preparing
17:51:17.395 - * s:0 q:0 tr=0 (0) Preparing
17:51:18.397 - * s:0 q:0 tr=0 (0) Preparing
17:51:19.398 - * s:0 q:0 tr=0 (0) Preparing
17:51:20.399 - * s:0 q:0 tr=0 (0) Preparing
17:51:21.401 - * s:0 q:0 tr=0 (0) Preparing
17:51:22.402 - * s:0 q:0 tr=0 (0) Preparing
17:51:23.684 - * s:0 q:0 tr=0 (0) Preparing
17:51:24.405 - * s:0 q:0 tr=0 (0) Preparing
17:51:25.407 - * s:0 q:0 tr=0 (0) Preparing
17:51:26.408 - * s:0 q:0 tr=0 (0) Preparing
17:51:27.410 - * s:0 q:0 tr=0 (0) Preparing
17:51:28.421 - * s:0 q:0 tr=0 (0) Preparing
17:51:29.412 - * s:0 q:0 tr=0 (0) Preparing
17:51:30.414 - * s:0 q:0 tr=0 (0) Preparing
17:51:31.415 - * s:0 q:0 tr=0 (0) Preparing
17:51:32.417 - * s:0 q:0 tr=0 (0) Preparing
17:51:33.428 - * s:0 q:0 tr=0 (0) Preparing
17:51:34.420 - * s:0 q:0 tr=0 (0) Preparing
17:51:35.431 - * s:0 q:0 tr=0 (0) Preparing
17:51:36.422 - * s:0 q:0 tr=0 (0) Preparing
17:51:37.424 - * s:0 q:0 tr=0 (0) Preparing
17:51:38.425 - * s:0 q:0 tr=0 (0) Preparing
17:51:39.437 - * s:0 q:0 tr=0 (0) Preparing
17:51:40.428 - * s:0 q:0 tr=0 (0) Preparing
17:51:41.430 - * s:0 q:0 tr=0 (0) Preparing
17:51:42.431 - * s:0 q:0 tr=0 (0) Preparing
17:51:43.453 - * s:0 q:0 tr=0 (0) Preparing
17:51:44.434 - * s:0 q:0 tr=0 (0) Preparing
17:51:45.445 - * s:0 q:0 tr=0 (0) Preparing
17:51:46.447 - * s:0 q:0 tr=0 (0) Preparing
17:51:47.438 - * s:0 q:0 tr=0 (0) Preparing
17:51:48.450 - * s:0 q:0 tr=0 (0) Preparing
17:51:49.441 - * s:0 q:0 tr=0 (0) Preparing
17:51:50.443 - * s:0 q:0 tr=0 (0) Preparing
17:51:51.454 - * s:0 q:0 tr=0 (0) Preparing
17:51:52.446 - * s:0 q:0 tr=0 (0) Preparing
17:51:53.457 - * s:0 q:0 tr=0 (0) Preparing
17:51:54.448 - * s:0 q:0 tr=0 (0) Preparing
17:51:55.460 - * s:0 q:0 tr=0 (0) Preparing
17:51:56.471 - * s:0 q:0 tr=0 (0) Preparing
17:51:57.453 - * s:0 q:0 tr=0 (0) Preparing
17:51:58.454 - * s:0 q:0 tr=0 (0) Preparing
17:51:59.456 - * s:0 q:0 tr=0 (0) Preparing
17:52:00.457 - * s:0 q:0 tr=0 (0) Preparing
17:52:01.458 - * s:0 q:0 tr=0 (0) Preparing
17:52:02.470 - * s:0 q:0 tr=0 (0) Preparing
17:52:03.461 - * s:0 q:0 tr=0 (0) Preparing
17:52:04.473 - * s:0 q:0 tr=0 (0) Preparing
17:52:05.514 - * s:0 q:0 tr=0 (0) Preparing
17:52:06.466 - * s:0 q:0 tr=0 (0) Preparing
17:52:07.467 - * s:0 q:0 tr=0 (0) Preparing
17:52:08.469 - * s:0 q:0 tr=0 (0) Preparing
17:52:09.480 - * s:0 q:0 tr=0 (0) Preparing
17:52:10.471 - * s:0 q:0 tr=0 (0) Preparing
17:52:11.473 - * s:0 q:0 tr=0 (0) Preparing
17:52:12.484 - * s:0 q:0 tr=0 (0) Preparing
17:52:13.476 - * s:0 q:0 tr=0 (0) Preparing
17:52:14.477 - * s:0 q:0 tr=0 (0) Preparing
17:52:15.479 - * s:0 q:0 tr=0 (0) Preparing
17:52:16.480 - * s:0 q:0 tr=0 (0) Preparing
17:52:17.482 - * s:0 q:0 tr=0 (0) Preparing
17:52:18.493 - * s:0 q:0 tr=0 (0) Preparing
17:52:19.484 - * s:0 q:0 tr=0 (0) Preparing
17:52:20.486 - * s:0 q:0 tr=0 (0) Preparing
17:52:21.497 - * s:0 q:0 tr=0 (0) Preparing
17:52:22.489 - * s:0 q:0 tr=0 (0) Preparing
17:52:23.500 - * s:0 q:0 tr=0 (0) Preparing
17:52:24.502 - * s:0 q:0 tr=0 (0) Preparing
17:52:25.493 - * s:0 q:0 tr=0 (0) Preparing
17:52:26.494 - * s:0 q:0 tr=0 (0) Preparing
17:52:27.496 - * s:0 q:0 tr=0 (0) Preparing
17:52:28.497 - * s:0 q:0 tr=0 (0) Preparing
17:52:29.499 - * s:0 q:0 tr=0 (0) Preparing
17:52:30.500 - * s:0 q:0 tr=0 (0) Preparing
17:52:31.502 - * s:0 q:0 tr=0 (0) Preparing
17:52:32.503 - * s:0 q:0 tr=0 (0) Preparing
17:52:33.515 - * s:0 q:0 tr=0 (0) Preparing
17:52:34.696 - * s:0 q:0 tr=0 (0) Preparing
17:52:35.507 - * s:0 q:0 tr=0 (0) Preparing
17:52:36.509 - * s:0 q:0 tr=0 (0) Preparing
17:52:37.510 - * s:0 q:0 tr=0 (0) Preparing
17:52:38.512 - * s:0 q:0 tr=0 (0) Preparing
17:52:39.513 - * s:0 q:0 tr=0 (0) Preparing
17:52:40.515 - * s:0 q:0 tr=0 (0) Preparing
17:52:41.516 - * s:0 q:0 tr=0 (0) Preparing
17:52:42.518 - * s:0 q:0 tr=0 (0) Preparing
17:52:43.519 - * s:0 q:0 tr=0 (0) Preparing
17:52:44.520 - * s:0 q:0 tr=0 (0) Preparing
17:52:45.522 - * s:0 q:0 tr=0 (0) Preparing
17:52:46.553 - * s:0 q:0 tr=0 (0) Preparing
17:52:47.525 - * s:0 q:0 tr=0 (0) Preparing
17:52:48.526 - * s:0 q:0 tr=0 (0) Preparing
17:52:49.528 - * s:0 q:0 tr=0 (0) Preparing
17:52:50.529 - * s:0 q:0 tr=0 (0) Preparing
17:52:51.530 - * s:0 q:0 tr=0 (0) Preparing
17:52:52.532 - * s:0 q:0 tr=0 (0) Preparing
17:52:53.533 - * s:0 q:0 tr=0 (0) Preparing
17:52:54.535 - * s:0 q:0 tr=0 (0) Preparing
17:52:55.546 - * s:0 q:0 tr=0 (0) Preparing
17:52:56.538 - * s:0 q:0 tr=0 (0) Preparing
17:52:57.539 - * s:0 q:0 tr=0 (0) Preparing
17:52:58.541 - * s:0 q:0 tr=0 (0) Preparing
17:52:59.542 - * s:0 q:0 tr=0 (0) Preparing
17:53:00.553 - * s:0 q:0 tr=0 (0) Preparing
17:53:01.545 - * s:0 q:0 tr=0 (0) Preparing
17:53:02.546 - * s:0 q:0 tr=0 (0) Preparing
17:53:03.548 - * s:0 q:0 tr=0 (0) Preparing
17:53:04.549 - * s:0 q:0 tr=0 (0) Preparing
