Ошибка к сожалению осталась.
Вот новый текст из dialog box под кнопкой Details.
System.IO.FileNotFoundException: Could not load file or assembly 'ProgDvbNet.Win, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. Не удается найти указанный файл.
File name: 'ProgDvbNet.Win, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null'
at ProgSatFinder.ChannelBase.LoadBase()
at ProgSatFinder.ChannelBase.GetSatPosition(List`1 in_list)
at ProgSatFinder.ScannerForm.StopScannerTimer1_Tick(Object sender, EventArgs e)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400)
ProgSatFinder
Assembly Version: 2.34.0.0
Win32 Version: 2.34.0.0
CodeBase: file:///C:/ProgFinder/ProgSatFinder.exe
ProgDVBNet.Base
Assembly Version: 1.0.1.0
Win32 Version:
CodeBase: file:///C:/ProgFinder/ProgDVBNet.Base.DLL
msvcm90
Assembly Version: 9.0.30729.6161
Win32 Version: 9.00.30729.6161
CodeBase: file:///C:/Windows/WinSxS/x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_50934f2ebcb7eb57/msvcm90.dll
System
System.Drawing
EngineApiWrapper
Assembly Version: 1.4.5.0
Win32 Version:
CodeBase: file:///C:/ProgFinder/EngineApiWrapper.DLL
Ionic.Zip.Reduced
Assembly Version: 1.9.1.5
Win32 Version: 1.9.1.5
CodeBase: file:///C:/ProgFinder/Ionic.Zip.Reduced.DLL
Accessibility
Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
enabled.
For example:
<configuration>
</configuration>
