The EPG needs a little work. When browsing up/down, the EPG will go to the beginning of the episode on the channel being highlighted. If that channel has a 12-hour event, the EPG will jump back XX hours and that makes it somewhat difficult to navigate.
Not sure the coding you're using to display the EPG's XML, but probably not too difficult to stay within the current time range.
Thoughts?
FYI, I love tinkering.. If you would be willing to let me see the code for that module, I would be willing to help for free...
Thanks!!
Re: EPG in IPTV using XML Link
#5Ok, I still think it would be easy to fix. I can get Visual Studio installed to look at it. That is if you don't mind.
We can chat ina private message if you'd like.
#7Only tinkering, but I'm good at reverse engineering code and figuring things out. I can send you what I find and let you implement it after reviewing it.
#8Hi prog; why the EPG is not showing the same way like in Kodi, Perfect Player, together with the channel,and not showing on a separate page?this is on Computer and the same goes for Android?
