I'd like to know if it'll have support to Video on Demand (VOD) in future versions of ProgDVB or if it's posible to do that now in the current versión
Thank you
Re: VOD Support
#2It is possible in current version. For format you use? What error message when you try?
Re: VOD Support
#3I'm testing your new update v7.22.7 but it doesn't play VOD
I've seen that the format of the videos is *.mkv and tell you that it doesn't appear error
Thank you for your support
Re: VOD Support
#5What do you need to try or resolve the problems with VOD?
When I use VLC, i can play the videos but I prefer to use your program for all XD
Re: VOD Support
#7I don't have a log file in my program directory to send you because the program don't crash. Some errors that i got:
Video Render Creating Error and I can push to go the codecs options
Second try: Error in default graph building! Tipo de pista: MPEG4
I've elecard codec to MPEG-2 and AVC/H264 codec.
When I open files mkv and others, I don't see nothing but i can see traffic data
If you need something more or you need other thing, tell me again to try recover for you
Thank you for your help
Re: VOD Support
#8Check codec for mp4 in Options->Video->Codecs.
ps: You can install LAV and select for near all video types.
