This what's in progdvb.log
IP filter file not found (C:\Program Files\ProgDVB\Modules\htdocs\ipfiler.txt)
CTS_TSConverter::BuildElecardGraph()
Exeption in start BuildElecardGraph
I've tried to do that, change couple of decoders. Is it possible that there is conflict between coders, couse I had Cyberlink PoweDVD installed on system?
I've reinstalled my PC and set IPTV server but it only runs when i use transport stream/all streams. When I set TS transcoding the stream stops.
Is there anything else I need to do for transcoding to work.
I have installed SD MPEG-2 Encoders pack for transcoding (21 days trial period). Do I have to do anything else.
Tnx
limitator wrote:I've reinstalled my PC and set IPTV server but it only runs when i use transport stream/all streams. When I set TS transcoding the stream stops.
When building transcoding graph on you system, you got crush, that`s why transcoding does not work. May be it`s because selected decoder (video, sound) is not compatibly with encoder. Try to use another, and watch log (it`s change or not).
