Hi
I'm trying to use ProgDVB media server to allow client to watch TV through Wifi.
When I use the setting Stream type: Transport Stream/All streams
Everything is fine(Execpt the speed which is limited to 2.5MB/s on wifi and everything is slow)
However I can't use AVC or TS. When I select them nothing appears on client.
on client Quality meter is at 100%(although it shows about 5kB of lost packets which won't increase)
but the network graph shows at most 11kB/s
no picture on client.
Please tell me how I can setup the server correctly.
Re: Can't use AVC/TS to transport
#2Do you select encoder? Else try try install mpeg2 encoder pack from site.
ps: Packet size in server settings very important for WiFi.
