Hello, I have an OTA digital antenna and I would like to hook this up to my computer so I can link to it over the internet VIA an http/m3u8 link and have many of the channels available to watch, not just one. Can I use your program do do this? What do I need to connect the antenna with to my computer? (Please recommend a cheap TV Tuner I can get off eBay)
Do I need to get your Network version of the software to do what I want? (Stream many channels at once that I am getting OTA)
Thank you for any help
Re: Need guidance on setting up IPTV OTA streams/links
#21. You can buy DVB device in near shop and test it.
2. For streaming you need free version of ProgDVB + Prog Media Server. Or other server if you need HLS or transcoding.
#3Hello, thx for responding, so I need to get a PC DVB TV tuner that plugs into the computer VIA USB rather than the VGA connection so that your software sees it, right?
Once I get ProgDVB to see my tuner, is there a guide on what settings to enable to connect each channel to an http/HLS link to be able to access them from outside and also inside my network? I will like to stream 3-4 channels at the same time.
Thx again for your guidance
#4From one mux. And my server not support hls.
#5What is 'one mux'?
What does your server stream then if not live OTA channels? only mp4 or local media files?
The channels will be OTA channels, I won't be able to stream these? What program would you recommend then to stream OTA channels?
Can I create my m3u8 link from your ProgDVB program then stream it through VLC or somthing? Thx
