#1052
Prog wrote:At first try remove files in channels directory and scan again.
as i dont want lose my sorted channels by myself, just make a copy of channels directory then deleted all files in this directory. start progdvb and scanned "RTL 102.5 TV" frequency , founded and added to list, now i just make a trick :D right click on "RTL 102.5 TV" and Copy , paste it in Notepad++ . this is what i saw:
{10704,558345804494,0 dev 2,0,3635075002022849395}
now i close ProgDVB and restored the backup directory i was made before(Channels folder) to the progdvb setup folder, open ProgDVB again, "RTL 102.5 TV" was showing by ProgDVB but it was not in the list,so i changed channel. now i copied all the text that was in the Notepad++ and pasted it into channel list, tadaaaaaa :) now i have "RTL 102.5 TV" in my own channel list. ;)
ps: but still there is problems with progdvb deleting channels automatically & can't add them again to list & making new channel manually by user (add PID and other stuff...) or edit a existing channel to change PID....
Regards FTA_Boy
RTL 102.5 TV.txt.zip
RTL 102.5 TV.txt
(186 Bytes) Downloaded 359 times
#1056
dmart wrote:When are you going to fix a very annoying bug of fullscreen navigation? I checked the latest version 6.85.06. The bug is still there. It is impossible to use ProgDVB in fullscreen right now.
I repeat my previous (simplified) bug description:
1. Press <Enter> on keyboard to open LIST1 and select a channel.
2. Press <Enter> again and then go to LIST2 with arrow keys and select a new channel.
3. Thats it... ProgDVB no longer listens to pressing <Enter>.
LIST1 and LIST2 are custom created channel lists e.g. Info, Music, Documentaries etc.
I am not can repeat this problem. What video render and OSD mode? What RC module?
The bug is gone in the new version. Thanks for fixing this. Identical bug remains when I press "previous channel" or "next channel" buttons (channel history). Render is EVR CP/W7/32.
#1057
1) After changing Audio track CPU-->100% and sometimes crash.
Multiple bugs in Parent Control.
2) When channel triggers PC (lets say content has mark >+17) password is required but regardless of entering correct or wrong password ProgDVB says "no channel" and it is impossible to switch to any other channel after that, it shows "no channel" for all the channels. Only removing LastChannelId from INI file helps.
3) It is impossible to disable Parent Control in Settings. Even if it allows to disable PC from Settings it remains enabled forever. I could not find anything to remove from INI file to actually disable PC :(
ProgDVB v6.86.4
#1060
H3lli0n wrote:Hi ,
I installed the brand new 6.87 version and it is worse than 6.86.4.
The software can't lock my HD channels H264/E-AC3, the SD mpeg2 are slower to lock as well :/.
I reinstalled the 6.86.4 version and all have been working again :/
i think kinda have same problem but its about ac3 codec , ac3 codec not work anymore tried different ac3 codecs with no success , when open a ac3 channel progdvb cant lock that channel and show till i select a mpeg (mp3) track for that channel ( channel using x264 codec )...
