Version 7.02.01
With this new version I cannot change the channels (DVB-S)
an the program stops working when updating EPG.
With 7.02 everything is working fine.
Greets
MB
#1442What device? May be some conflict with old version...
#1444So now I tried the following, starting with 7.02:
Updating to 7.02.01: only problems (no EPG, no channel changing ...)
Updating first to 7.02.01 and directly to 7.02.02 same problems
Updating directly to 7.02.02 everything is working fine until now!
There must be a problem in the 7.02.01. Even I cannot find channels
in vertical polarisation ba manual search.
But now I use the 7.02.02.
Greets
MB
Greets
MB
#1445hi prog, i was using ProgDVB and changing some channels but suddenly ProgDVB disappeared with out showing any warning and closed ... went to task manager no process by progdvb was running!!! after i opened ProgDVB again Recovery windows poped up. Weird.
here is the log file link :
http://p30up.ir/images/shxtmeboh421r8a6k53.zip
Thanks
Thanks
#1446Prog wrote:Please send me logs with ac3filter. This filter good working on all my samples.
Needless because I found the solution. I discover sometimes audio works, and sometimes not when i refresh the channel.
I also went in the windows xp.
video/HD:arcsoft.
audioCode:arcsoft.
audioCodeHD:ac3.
rtve HD channels use dolby digital+ 2.0 and Dolby Digital 5.1.The problem is the arcsoft codec. So I change to this:
video/HD:arcsoft.
audioCodec:ac3
audiCodecHD:ac3
And no more problems, so if you have a dolby digital+ channel, not use arcsoft codec, is incompatible. Thats all
winxp,pctv 310i analog,fm,DVB-T,skystar HD2 + CI dvb-s2
#1447hello dear Prog , i just wanna mention that this problem is still here , can you fix it ? :
FTA_Boy wrote:here is another bug, when i open ProgDVB and splash-screen is showing (loading to open progdvb), meanwhile again quickly i double click on ProgDVB icon (open another ProgDVB) it will open multiple process and this will crash progdvb and cause other problem & activation(license) problem... as you can see in this photo :
http://p30up.ir/images/f6mhrkitiy8bm7zoq6f.jpg
- no tagged pics, PLEASE. Use links ins ... .jpg[/img]
after closing progdvb and all Recovery windows if i open ProgDVB there might be some problem...
but when progdvb is fully open and i open another progdvb , the running progdvb will pop up and it is good (ok), no more multiple process. so this problem only happen when splash-screen is showing and loading for open progdvb...
this is old problem.
ps: i'm using 6.97.4 F Pre-release but in about windows and splash-screen its showing : 6.97.4e
#1449thanksProg wrote:Try "c" prerelease.
frequently Crash in unmanaged part!
#1450Code: Select all
VideoParser::mpeg2::Sequence header detected!
PES packet to large!
Cache overload (湉潣業杮匠牴慥慃档e3DIM700.DLL -5120000) !!!
- * s:26 q:46 tr=8523732 (376564)
- !! TopLevelExceptionFilter !! ACCESS_VIOLATION/Continuable
- module: ProgDvbEngine.dll
- thread: 0xd08 Re: bug feedback - post newly found progdvb bugs here
#1451hello again Prog
#1 : when i resize ProgDVB windows from maximized to center of screen for example (like this picture: ) and then i click maximize and again i click on that button to restore the custom sized window before i was using , ProgDVB will go full sized instated of the size i was using before maximize.
EDIT : this a problem with "Snap to desktop border". i unchecked it and i don't have this problem any more.
#2 : when i pause Timeshift , ProgDVB doesn't show the thumbnail (small picture) for timeshifted video but the played part of timeshift showing the the thumbnail. timeshift should be played (showed) to have small picutre, the buffered part which is not played yet dont show the thumbnail. look at this picture : #3 : here is a crash log i like to let you know :
***ExceptionReport.txt :
time: 8.3.2014 5:27:33
Type: Crash in unmanaged part
Module: C:\Program Files\ProgDVB\ProgDvbEngine.dll
Thread: 0x1d74
***ProgDVBEngine.log :
Thread: 0x1d74
05:27:25.015 - ########################### Mark of finish channel changing. (5.101ms) #############
05:27:25.015 -
05:27:25.629 - * s:17 q:37 tr=364532 (0)
05:27:26.643 - * s:17 q:36 tr=382392 (0)
05:27:26.788 - C:No key!
05:27:27.657 - * s:17 q:36 tr=424316 (0)
05:27:28.671 - * s:17 q:37 tr=421684 (0)
05:27:29.042 -
05:27:29.042 -
05:27:29.042 - ########################### Mark of start channel changing.###########################
05:27:29.042 -
05:27:29.043 - GraphManager::MainChangeChannel BBC Entertainment Poland
05:27:29.043 - DevicesManager::DestroyAllTransponderManagerUsedForSetTransponders
05:27:29.043 - CSetChannelLogic::SetChannel 0
05:27:29.043 - CSetChannelLogic::SetNormalChannel
05:27:29.043 - ChannelGraph5::StopChannel BBC Entertainment Poland
05:27:29.043 - TimeShift::Cursor PushMode 0 0 (0)
05:27:29.044 - ReaderCursor::SetPosition 0 (w=1269000)
05:27:29.044 - Prereader::EnablePushModeAndStartPlayback 0
05:27:29.044 - CPreScanner::Stop
05:27:29.044 - PlayTimePmtParser::StopParser
05:27:29.044 - CSubtitlesPrsersManager::StopChannel
05:27:29.046 - Graph::Stop
05:27:29.080 - Graph::ReleaseAllFilters
05:27:29.101 -
05:27:29.101 - TransponderManager::SetTransponder (CH) 11117000 BBC Entertainment Poland
05:27:29.102 - Api2Device::SetChannel 11117000Khz sid=14602
05:27:29.102 - ch:BBC Entertainment Poland {freq:11117, pol:V, sr:27500}
05:27:29.124 - Error! Crash in CTimeManager::DoPause()
05:27:29.552 - Api2Device::SetChannel result OK
05:27:29.552 - TsInputTrafficProcessor::OpenTransponder 1
05:27:29.552 - FilterManager::OnSetTransponder SetChannel
05:27:29.552 - TimeShift::Reset
05:27:29.553 - TimeShift::Cursor reset
05:27:29.553 - Prereader::Reset
05:27:29.553 - ModuleList::ChangeChannel 11117000
05:27:29.553 - DvbEpgParser::SetChannel 11117000
05:27:29.555 - CChannelGraph5::StartChannel BBC Entertainment Poland
05:27:29.555 -
05:27:29.555 - #################### Start stream. (0.515ms) #######################
05:27:29.555 -
05:27:29.559 - TimeShift::Cursor SetChannel
05:27:29.559 - ReaderCursor::SetPosition 0 (w=0)
05:27:29.559 - Prereader::SetChannel mask
05:27:29.560 - Plugin::SetChannel 14602
05:27:29.560 - TransponderManager::SelectChannel
05:27:29.561 - TsInputTrafficProcessor::SelectChannel 14602
05:27:29.561 - Api2BaseModule::UpdateAllOpenedChannels 1
05:27:29.561 - TsInputTrafficProcessor::UpdateChannel 14602
05:27:29.562 - PreScanner::StartChannelIsReady
05:27:29.562 - ChannelGraph5::AfterDetectChannelParams
05:27:29.562 - VideoMediaTypeDetection: mpeg2
05:27:29.562 - SimpleTsDemux::Init apid=6112, vpid=6101
05:27:29.562 - TimeShift::Cursor PushMode 1 1 (0)
05:27:29.563 - ReaderCursor::SetPosition 0 (w=0)
05:27:29.563 - Prereader::EnablePushModeAndStartPlayback 1
05:27:29.563 - PreScanner::StartPmtParserIfNeed
05:27:29.563 - PlayTimePmtParser::OpenParser 14602
05:27:29.563 - Graph::UpdateRenderMode
05:27:29.564 - Graph::SetVideoRect {8 8 712 568}
05:27:29.564 - Graph::SetVideoWindowRect {94 0 1072 734}
05:27:29.564 - ChannelGraph5::SetActiveState 1
05:27:29.582 - First data in TS buffer
05:27:29.685 - * s:29 q:47 tr=-3332864 (5452)
05:27:30.699 - * s:29 q:47 tr=370172 (9212)
05:27:31.713 - * s:29 q:47 tr=382580 (13536)
05:27:32.727 - * s:29 q:47 tr=381828 (8272)
05:27:32.952 - c:key 0
05:27:32.953 - c:key 1
05:27:32.984 - VideoParser::First packet 7916 mpeg2
05:27:33.154 - VideoParser::packet 56296
05:27:33.154 - VideoParser::mpeg2::Sequence header detected!
05:27:33.185 - AudioParser::First packet 2304
05:27:33.185 - AudioParser::MPG12 detected
05:27:33.186 - PreScanner::Post_InitRender
05:27:33.186 - ChannelGraph5::uiThread_CreateGraphAfterDetectOfMediaTypes
05:27:33.186 - TimeShift::Cursor PushMode 2 0 (0)
05:27:33.186 - ReaderCursor::SetPosition 0 (w=124268)
05:27:33.187 - Prereader::EnablePushModeAndStartPlayback 2
05:27:33.187 - ChannelGraph5::CreateInterfacesAndRenderGraph
05:27:33.249 - !! TopLevelExceptionFilter !! ACCESS_VIOLATION/Continuable
05:27:33.249 - module: C:\Program Files\ProgDVB\ProgDvbEngine.dll
05:27:33.250 - thread: 0x1d74
05:27:33.251 - !! TopLevelExceptionFilter !! ACCESS_VIOLATION/Continuable
05:27:33.251 - module: C:\Program Files\ProgDVB\ProgDvbEngine.dll
05:27:33.251 - thread: 0x1d74
05:27:33.252 - !! TopLevelExceptionFilter !! ACCESS_VIOLATION/Continuable
05:27:33.252 - module: C:\Program Files\ProgDVB\ProgDvbEngine.dll
05:27:33.252 - thread: 0x1d74
05:27:33.253 - !! TopLevelExceptionFilter !! ACCESS_VIOLATION/Continuable
05:27:33.253 - module: C:\Program Files\ProgDVB\ProgDvbEngine.dll
05:27:33.254 - thread: 0x1d74
#1452hi again. there is a problem with switching channel from DVB-S to Internet TV/Radio channels or reveres. the title of windows of progdvb will change to that channel but it wouldn't switch. i cant go back to DVB channels.
and Timeshit on internet tv not work
also the problems i mention on my previous post still exist.
thank you
thank you
#14531. Thanks for good idea. I try retest that later.
2. I am not like do SECOND playback crash for background. This is request more resources and less stability.
3. Too many reasons for this crash. Try repeat without plugin or
Please give me more information and log about problem with Internet TV.
#1455still problem with high bitrate sat even with NoGraphlog quickly grows to 15 MB!
- Cache overload (湉潣業杮匠牴慥慃档e Files (x86)\ProgDVB\Transponders\InterဠᗪtT N -5120000) !!!
- PES packet to large!
- CreateCustomGraph
- VideoType:MPEG2
- Video/MPEG2_VIDEO : MPEG2_VIDEO s={0,0,1920,1080}, t={0,0,1920,1080}, bmp=1920x1080, r=16/9, br=15305200,frametime=40ms, IF=0x0, CF=0x0)
- module: C:\Program Files (x86)\ProgDVB\ProgDvbEngine.dll
- thread: 0x994 .Prog demux pusher thread
