Re: Problem with shift-key
#18I confirm no change. Also tried under Windows XP (and different machine): the same issue arises. Could it be linked with the language of the OS (keyboard input)?
#19Please try update this file
http://test.progdvb.com/48/UnivHIDRemot ... cModule.7z
Same problem? What message on start of ProgLauncher and exit from ProgDVB?
#20Thank you.
It does not fix the issue.
This module does not load under 64 bit version (Universal HID Remote Control no longer appears in the list)
Under 32 bit version, when loading ProgDVB, I get a popup titled "HID" with "ProgDVB" written inside.
Nothing when exiting the app.
When loading Proglauncher, I get a popup titled "HID" with "Proglauncher" written inside.
#21But do you still have problem in x32? (when ProgLauncger started but no ProgDVB!!)
#22No it does not fix the problem. Except the popup, everything is the same.
#23Please test one more version.
#27Prog, I can't check these files till weekend.
Please, could you upload all these files and not overwrite them (for example with different 7z file names)?
I'd like to try all of them.
TIA.
TIA.
