Hi
for Kworld dvb-s owners :
I think you have to remove option which is kworld  from Card Modules  list with installer .
and could put it in Card Modules section (
not included with ProgDvb installer).
cause that device is bad for kworld cards and it's
not work if you don't have that old Formal dvb app by Kwolrd .
which is now no longer exist .
plus that device has some problems like crash. slow . BTW only ProgDvb support this old device .
and newer user that use progdvb first time he will choose simply during first install kowrld and say oh that is
 and later he will say what a bad kworld card I have. or someway with the the usb card or the newer version of pci card he will
not work because Kworld remove that old formal dvb app and now they use another app called Hypermedia .
simply the best ProgDvb setting for Kworld after install driver without installing their formal app is to set BDA compatible card and set type of BDA Kowrld from Device BDA option .
and it will work good  plus RC is supported by Kworld for ProgDvb and you can find it from the official website
